Page <1234> |
Pod_Geek
Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 261 |
Calendar Event: 2021 RPOD 190 water/electric ?Posted: 11 Jun 2020 at 9:53am |
My Autoformer warned me of a pedestal problem (bad ground) before I ever hooked up the Pod to shore power, so we moved sites. Does the EMS surge protector do something similar? I really don't know...
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
Posted: 11 Jun 2020 at 12:26pm |
The EMS surge protector should warn you as well. It would lack some of the Autoformer functions, but should protect you from connecting to a defective pedestal provided you hook it up first to test before you plug in your RPod.
Andyrpod190
Joined: 03 May 2020 Location: NH Online Status: Offline Posts: 40 |
Posted: 11 Jun 2020 at 12:35pm |
Thanks. I am thinking of this one for now. Provides sure protection, will power off if fluctuations are within certain parms and power back on when power stablizes.
At a price of $209 seems like a good balance.
AC
Posted: 11 Jun 2020 at 1:19pm |
Yes, that is probably a good choice between cheap throwaway and booster. I looked at the specifications on the Hughes web site and a good thing about that one is that the surge protection module is replaceable. The Camping World price is a bit better than the Hughes web site and the free shipping makes it a sweeter deal. I like that it has a phone app for monitoring which my model lacks.
Andyrpod190
Posted: 11 Jun 2020 at 1:40pm |
Great thanks!
Since my electrician is coming tomorrow, what do I need to account for since the distance from our power line from the Rpod and outlet may be about 40'?
AC
Posted: 11 Jun 2020 at 2:08pm |
I assume you mean the distance from your electrical panel to the rPod outlet. 40 ft is nothing, you'll be fine, 2% voltage drop at the full 30A using 10 gauge wire which is the minimum wire size required. Your electrician does this for a living. no worries.
Andyrpod190
Posted: 11 Jun 2020 at 2:11pm |
No i Mean from the Rpod190 to the outlet? Is there any limit?
AC
Posted: 11 Jun 2020 at 2:16pm |
Your existing power cord will be just fine. Due to where I installed my outlet, I do use one 50' RV 30A extension cord and I place the plug and socket under a cover so it won't be exposed to direct weather. I recommend getting some dielectric grease to put on the contacts. That will help keep the connectors in better shape and protect against corrosion.
Andyrpod190
Posted: 11 Jun 2020 at 2:19pm |
Hi Stephen.... I think I know the answer but my power connection on the Rpod might be 40 or so feet from the outlet I need to plug into at my house. It sounds like as long as you dont use mult ext cords a single 30amp service cord of 40 or 50' will be fine.
AC
Posted: 11 Jun 2020 at 2:23pm |
A 40 ft cord will have the same max voltage drop as the permanent wiring would for the same distance, because its the same gauge. So, 2%, which is fine.
Page <1234> |
