ouR escaPOD mods |
Page <1 3637383940 58> |
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1097 |
Topic: ouR escaPOD modsPosted: 01 Mar 2020 at 4:22pm |
I used a standard 30amp Rv female receptacle and waterproof cover on the trailer end that is wired to the controller. I attached a standard 30amp male end to the solar panels with mc-4 connectors. There is a 30 amp fuse between the controller and the batteries. here is a picture of the 25' power cord with the entire system. you can see the 30 amp female receptacle located on the pod frame at the front next to the A frame-the male end of the 25' power cord is plugged here here is a picture of the spliced 30 amp male plug end using mc 4 connectors to the solar panels-the female end of the 25' cord is plugged into the collectors here is a picture of all of the materials used As others have noted, I have used 120v AC connectors mixed in with 12vdc connections which is NOT standard practice.Also note that different from these pictures, my current installation is on our newer 179 and not the older 173 as shon and also the fuse has been moved to inside the cargo area to be waterproof. I hope this helps Vann
Posted: 01 Mar 2020 at 8:01pm |
I would not want to use the AC connectors and since I am using my 120V cords, would not want to use one for that purpose either. As I wrote earlier, it is moot since I purchased the 20' extension set. I just need to tie them together. I just bought a bag of zip-ties from Harbor Freight. They should work for the purpose. I will get some connectors that can handle the repeated plugging and unplugging to use in place of at least some of the ones that are not meant for repeated use.
Posted: 01 Mar 2020 at 9:37pm |
I decided to go with the same connectors and boots. I will replace some of the other connectors so that I can have a reliable quick-disconnect for the wiring. Thank you for the information.
Posted: 02 Mar 2020 at 6:05am |
Anderson makes good stuff, it handles high currents, can be booted, is polarized so you can’t reverse polarity accidentally, and can’t be confused with other ac or dc connectors on the trailer. What more can you ask for?
Posted: 02 Mar 2020 at 7:55am |
geewizard
Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Posted: 02 Mar 2020 at 8:13am |
Glad you find the Anderson connector info useful. Regarding using cable ties, what I did to avoid them was to lay out my two conductors on the lawn then twist them together. Not tightly but about one twist per foot. They work for me that way WITH MY CABLE. |
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Posted: 02 Mar 2020 at 9:01am |
Instead of cable ties, you might consider a wire loom (like this). It will keep the wires together and not tend to get caught up on things. Maybe wrap some tape or shrink wrap every 4 feet or so.
Posted: 02 Mar 2020 at 1:53pm |
If the wire loom were not split and if it were more flexible, I might consider that. The problem with shrink tubing is that it is hard to fit over existing connectors. If I were working from just the wires, it would work. I ended up going with the cable ties every couple of feet. I found that I can fit the 25' extension cord in the space behind the panels with no problem.
Posted: 03 Mar 2020 at 9:52am |
There is also the spiral wound wire loom like this. You could just use a 12" section of it every few feet. I kind of like it because it is easy to remove without cutters.
Posted: 03 Mar 2020 at 3:54pm |
I saw the spiral wound loom and did not like it.
