  New Posts New Posts RSS Feed: New owner.
Topic ClosedNew owner. - Event Date: 09 Feb 2020
Michiganders View Drop Down
Direct Link To This Post Calendar Event: New owner.
    Posted: 09 Feb 2020 at 8:58pm
Just got our 2019 R-Pod 189 on Friday. Has anyone added a open cabinet above the bed ?
Direct Link To This Post Posted: 09 Feb 2020 at 9:02pm
Welcome and congratulations! I hope you have many fun adventures and make many great memories doing so.
I added a shelf above the bed in our 2016 RPod 179. You can see it in my mods (link in signature).
crw8sr View Drop Down
Direct Link To This Post Posted: 09 Feb 2020 at 9:52pm
Welcome.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Direct Link To This Post Posted: 11 Feb 2020 at 8:08pm
Thanks for your reply. The pics are a great help. We are planing a cross country trip , hopefully for sometime this year.
F150, 2.7 Eco Boost.
Direct Link To This Post Posted: 11 Feb 2020 at 8:26pm
At first, I had the weight mainly resting on the valences, using command strips to hold the brackets I made to the wall. I later switched to anchors (if you drill into the wall, make sure anything you put in there is an inch or less. Otherwise, you will go through the outer wall. I made that mistake and learned quickly not to use anything over an inch long, preferably shorter. I think I mentioned doing so in one of my mods post, but it might have been in a different place also. The valences are not made to hold weight, so you will need some way to carry the weight. Some people have found the same shelf and instead of making brackets like I did, drilled the ends of the shelf and put in adjustable feet that can be tightened against the walls to carry the weight and hold it in place. You would need to search. Using the Advanced Search allows you to expand the date range. The default is to only search posts within the past six months. Advanced search lets you search older topics and posts also.
We are planning a cross-country trip that will also include Canada and into Alaska before turning south and heading to see our daughters and grandchildren before returning home.
