ouR escaPOD mods |
Page <1 2425262728 58> |
| Author | ||
Topic: ouR escaPOD modsPosted: 02 Jun 2019 at 3:08pm |
The main thing you're trying to achieve is to support the axle ends and carry a portion of that load in the angle back to the supports. So if someone wants to try shims the most important place to put them would probably be under the support points. Otherwise the angle wouldn't be in direct contact with the axle there and would probably deflect more than would be desirable. By bending the angle its in more or less direct contact with the axle for its whole length so you don't have to worry about it.
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Posted: 02 Jun 2019 at 3:51pm |
DavMar
Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 02 Jun 2019 at 4:59pm |
Your simple drawing was like a thousand words, now I understand how you bent the angle iron. Thanks! |
Posted: 02 Jun 2019 at 7:42pm |
I don't think anyone will accuse me of being an artist, but I'm glad my sketch was helpful. It turns out I do need to trim a little from the outboard side of the brackets on the end. They are too close to the arm and may interfere if they shift even a little. Edit: I did take the end brackets off and removed some of the material to give better clearance for the arm. There is now a distinct 1/4" space between the end of the bracket and the end of the axle tube, which matches the clearance for the reinforcing angle.
Posted: 03 Jun 2019 at 5:16am |
The axle isn't a teeter totter, its a double ended cantilever. The stress on the axle is the same everywhere between the two supports. So, to function as cantilevers both the axle and the supporting angle need to run the entire length as continuous parts. if you made the angle discontinuous then yes you would want to clamp it to the axle inboard, but that would just create a high stress location on the axle at that point, so it would bend there instead of at the supports. By making both parts continuous there is no need for clamps except at the ends, everywhere else the angle is supporting the axle because the axle is being bent downwards in the center by the end loads.
Posted: 03 Jun 2019 at 8:57am |
There is an advantage to having a center support though. When I took off the end brackets (one at a time) to shorten the overhang so the brackets would not be at risk of hitting the arm, it was good to have the center support to hold the angle in place while I was working on the brackets. If I did not have that center support, it would have been harder to do the bracket modification needed. Addendum: I decided to seal along the upper edge of the reinforcing angle, but not the ends. The seal should keep water out and decrease chances of corrosion. The camber should help any water that might get in to drain toward the ends where it should drain at the bottom of the V channel at the end by the arms. I used DAP Dynaflex Ultra Window, Door, Siding & Trim. The color I used is black to match. The product says "Crack Proof, Resists UV Fading & Dirt Build Up, Weather MAX Technology. One thing that helped me decide to use this is the specifications which include Flexibility: Permanently Flexible and Joint Movement: +/- 35%. I used less than a tube for the job.
Posted: 04 Jun 2019 at 5:24am |
I was thinking about doing that but decided against it and just gave both the axle and the angle a good coating of rustoleum before mating them up. Either way, I'm sure my setup will rust faster than yours because of the salt environment here on the OBX. I had to grind and refinish my A frame this spring already due to corrosion there. We'll see what happens.
Posted: 04 Jun 2019 at 4:52pm |
Our first test will be soon when we go to Florida to see my parents. I'll be keeping a close watch on it to make sure the U bolts stay tight and the reinforcing angle does not shift.
Posted: 04 Jun 2019 at 6:35pm |
I'll be looking out for that as well but I don't think it will, its not like the axle is moving around, and the friction from the ubolts is really high. Unforlunately, it will be another month before I (hopefully) get to take a trip of any distance in our rPod.
DavMar
Posted: 04 Jun 2019 at 10:36pm |
Maybe I’m naïve but if there is a worry about water collecting
in the bottom of the V chanel of the angle iron why not drill a couple of small weep
holes in it? I don’t know if it would affect the strength of this steel brace but I don't believe it would. On a side note I'm looking very forward to reports on how this axle mod has worked out in real use over time. |
