zookagumby
Topic: Just bought a used Rpod Posted: 17 May 2019 at 11:49am |
LOL...yep, that's how I knew the brakes weren't working! After a long downhill, I just felt how hot the drums were...and they weren't. I'm in the process right now of disabling the self-adjusters; using a dremel to change the angle of the adjusting-star actuating plate edge so it can no longer engage.
Tom
2019 Ram 1500, 2016 Rpod 177
Posted: 17 May 2019 at 12:15pm |
Thanks but I'll stick with my IR thermometer. One of my favorite tools. Don't have to get down on my knees and reach around, and no burned fingers. Useful for lots of other things as well, like checking fridge and a/c evaporator temps.
BTW, you don't need a separate variable voltage power supply. An electronic brake controller already is a pulse width modulated power supply. It's voltage setting is the reading when you slide the manual lever to full.
podwerkz
Posted: 17 May 2019 at 12:26pm |
BTW, you don't need a separate variable voltage power supply. An electronic brake controller already is a pulse width modulated power supply. It's voltage setting is the reading when you slide the manual lever to full. |
No burned fingers here either....I'm good at this..and yeah, I also know how the brake controllers work.
And I own two IR guns me-own-self...
But...a variable voltage power supply is easier and works with no vehicle (or assistant) needed. You can dial up the exact voltage (usually 2-4 volts) that slightly engages the brake magnets, with just a small amount of rotational drag when both wheels are jacked up off the ground. Adjust the starwheels for a balance between both sides.
A simple lab supply with 0-15v and about 3 amps is sufficient for testing, as well as checking or servicing the lights on the trailer when its not hooked up to a vehicle.
Posted: 17 May 2019 at 12:45pm |
Are your fingers calibrated in Fahrenheit or Celsius?
I don’t need a helper or a power supply either, just adjust the controller to the voltage you want and tape the lever full on. Ain’t nothing you cain’t fix with duct tape.
podwerkz
Posted: 17 May 2019 at 1:57pm |
Right knuckles: Fahrenheit. Left knuckles: Celsius.
I do the F to C or C to F conversion in my head while I'm walking around to the other side and using the opposite hand. The smell of burning flesh means that there was a mountain behind me.
Hey, you asked!
Duct tape is fine, but my lab supply is calibrated to 1/100th of a volt. I be in the know, don't cha know.
Posted: 17 May 2019 at 2:06pm |
Originally posted by podwerkz
I don't need no stinkin' IR thermometer.....I just reach around and quickly touch the drums with the back of my knuckles. I can tell really fast if one is hotter than the other!
I will also grab the hubs, kick the tires, place my palm on the tread, and feel and smell for anything hot. I do this after nearly every highway run, when getting gas, taking a pee-break, whatever.
Of course, I've got a few million miles driving trucks. Comes with the territory. |
I know people who claimed they had calibrated elbows and did not need a torque wrench.
... but seriously, you would be amazed at how accurate you can get with things like this with a bit (or a lot) of experience. That said, using a tool (like an IR thermometer or torque wrench) is still a good idea for the rest of us who are not "calibrated" appropriately.
podwerkz
Posted: 17 May 2019 at 3:01pm |
After awhile a truck driver can learn by the sound of the tire buddy (or the flat palm) thumping the dual tires, about what they are inflated to. Now, you can't tell 90 psi from 100 psi just by thumping, but you can tell if all the rest are around 100 psi and one is low, say, 75 psi, just by the sound of the thumps.
And a really low tire will make a dull thud.
Boy did we wander off-topic....probably my fault...again...
Posted: 17 May 2019 at 5:58pm |
I have a calibrated tongue, as in when I put my tongue on battery terminals I can tell about what voltage it is (but not to 10mV like your power supply). And I've never tested my 200V Prius battery that way
Not that far off topic really yet, but we we're still working it....
Posted: 17 May 2019 at 6:14pm |
I have a pressure gauge, a torque wrench, an IR Gun, also EEZ tire system on Pod, and when I first got Pod I cleaned up the wiring and secured it on the bottom of Pod. Four years - no issues, knock on wood.
Posted: 17 May 2019 at 6:19pm |
I use the Zen of measurement and just go by what feels right.  And my brakes still work and the axle ain't bent yet.
