Buckeye
Topic: 50 or 30 amp Posted: 24 Jan 2019 at 9:27am |
Newbie question: when I research campgrounds, a 50 or 30 amp site is generally offered. What do I need for my 2017 180? Thanks. I'm sure the answer is somewhere, but I can't find it. Craig
Craig-retired teacher of the blind
Carol-retired legal admin asst
Spot and Sam-the miscreant Shih-tzus
"Politically incorrect with no real changes expected...”
Former 2017 Rpod 180
F150 5.0 4x4
tcj
Posted: 24 Jan 2019 at 9:40am |
30 amp. Check the power port, it is a 30 amp plug and your 180 should have come with a 30 amp cord.
2018 R-pod 180 Hood River Edition
ArenaBlanca
Posted: 24 Jan 2019 at 9:54am |
I encountered one campground last year that only had 50 amp sites. They provided a "dogbone" which allowed me to connect. But, just in case, I now carry a 30 to 50 amp adapter as well as a 20 to 30 amp. You never know what you are going to run into. At one place, the plug in was for a 30 amp but the circuit breaker was a 20 amp.
Enjoy Life!!
Posted: 24 Jan 2019 at 10:56am |
Yes. 30 amp. Many, if not most of the full hookup campgrounds provide 30 AND 50 amp connections. I've even been to a few with 15 amp connections.
Connecting a 30 amp TT to a 50 amp service is possible with an adapter, but it comes with some caveats. It would be best to have an adapter with a single pole 30 amp breaker built in, but you would have to spend some money to make that happen.
texman
Posted: 24 Jan 2019 at 11:29am |
i would suggest a protection device for voltage fluctuation to protect the Pod electronics as well. for instance:
Posted: 24 Jan 2019 at 11:53am |
The main caveat with using a 50 to 30 amp adapter is safety. Some of us are ok with it, some are not, and FR doesn’t recommend it. There is a long thread on that issue on this forum you could search for and reach your own conclusions.
Posted: 24 Jan 2019 at 2:12pm |
Originally posted by offgrid
The main caveat with using a 50 to 30 amp adapter is safety. Some of us are ok with it, some are not, and FR doesn’t recommend it. There is a long thread on that issue on this forum you could search for and reach your own conclusions. |
The main issue being that a 50 amp connection is split phase. IOW, it has two hot leads. To convert it to 30 amp, you only pull one of the hots, and leave the other one unterminated. So that leaves a couple of issues. One is that the unterminated lead must be protected from touching anything that it shouldn't. Two being the 2-pole breaker is only sensing current on one of the hots (instead of both of them). Just something to be aware of.
Posted: 24 Jan 2019 at 5:32pm |
The issue with connecting to a 120V system using one of the two hots from a 240V split phase service is there but it is readily solvable (the dogbones terminate one of the two hot leads internally), and the 50A 2 pole breaker will trip if either leg individually exceeds that rating.
The real concern is that you are connecting a 50A service to an electrical system designed for only 30A. That creates a fire risk and is an NEC code violation. The connector on your trailer says not to do it. Lots of people do it anyway, up to each individual to assess this risk and decide for themselves.
BTW, current electrical code requires pedestals with 50A service to also have 30A and 15A service, but until the campgrounds update their electrical systems you won't necessarily find this.
Buckeye
Posted: 24 Jan 2019 at 5:57pm |
Thank you all for your information. Craig
F150 5.0 4x4
ron_whitt
Posted: 24 Jan 2019 at 9:21pm |
Great info guys. I was thinking of getting a 50 to 30 amp dog bone. But now don't think I will.
Ron & Shirley
2020 Tacoma
2012 177 rpod
