  New Posts New Posts RSS Feed: 'bathroom' works kitchen sink doesn't
Topic Closed'bathroom' works kitchen sink doesn't
Happy Tripping View Drop Down
Direct Link To This Post Topic: 'bathroom' works kitchen sink doesn't
    Posted: 22 Apr 2018 at 4:41pm
Hello.
I have dewinterized, on city water the bathroom sink and toilet flush clean water, the kitchen sink dribbles. Shutting city water off and running on water in our tank, the water pump motor works while we use the bathroom, then shuts off when the pressure isn't needed, just like it's supposed to. Opening both the hot water and cold water faucet handles, the kitchen sink still dribbles and the water pump goes 'on' only briefly every-so-often. I removed the spout strainer and the faucet spout still just dribbles.
I am getting good pressure everywhere BUT the kitchen faucet, hot or cold. I haven't turned the water heater on yet.
??The problem seems to be in the water line(s) between the water pump and the faucets for BOTH hot and cold water??
I look forward to your comments.
HELP!
Pete Brayton View Drop Down
Direct Link To This Post Posted: 22 Apr 2018 at 5:00pm
Any chance that the valve for sucking antifreeze into your system is still open?
2021 Rpod 196
2013 Ford 150 V8
Direct Link To This Post Posted: 22 Apr 2018 at 5:11pm
Sounds like an obstruction in the water line that may have lodged itself inside the faucet.  Take a small flexible wire and push back as far as you can from the faucet outlet.  I would try this first w/o the outlets open to see if you can feel any obstruction.  If not, turn both outlets to open and repeat this procedure to see if the problem lies inside the faucet.  I am going outside right now to check my faucet to see where else to look or to do next.
Direct Link To This Post Posted: 22 Apr 2018 at 5:24pm
So I just unscrewed the unit that holds the faucet down, carefully pull up and the faucet comes off, you can easily see it there would be any obstruction there.  At that point I would quickly turn the pump on and off to see if any water comes out of the white plastic basin that the faucet base fits into.  If not the problem lies in the line between the water pump and that white plastic part, about 3 feet.  Possibly a kink in the line, between the water pump and the faucet, actually check this out before proceeding to do the above.  Hopefully you will solve this issue soon.  Let us know what you find.
Direct Link To This Post Posted: 22 Apr 2018 at 5:39pm
Ok.
While I was looking around for a length of thin wire to use as a probe, the little woman was whapping the flexible line going to the spout with the handle of a big crescent wrench. When the water was turned back on, a thin layer of grainy material was found in the bottom of the sink and the flow is now much increased.
Never underestimate the power of a big crescent wrench handle in the hands of a little lady!
So, I believe the problem is solved, but I don't remember encountering this previously in the forum.
Is it just our water?
Is there a preventative step that will avoid recurrence??
Thanks very much for your quick help!!
Direct Link To This Post Posted: 22 Apr 2018 at 5:49pm
Other than filtering your water line, there is nothing in a POD to do that. Not sure where she was whacking, but PEX lines don't easily kink. In future would ensure you're using filters.
Direct Link To This Post Posted: 22 Apr 2018 at 6:10pm
LOL definitely want to stay on the Little Ladies good side!!
Direct Link To This Post Posted: 22 Apr 2018 at 6:23pm
And exchange that crescent wrench with a plastic one, in case she gets mad at you!  Whap, whap !Ouch
Subzilla View Drop Down
Direct Link To This Post Posted: 23 Apr 2018 at 7:08am
May have to try this....our sink is quite dribblely.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Direct Link To This Post Posted: 23 Apr 2018 at 7:53am
I was quite surprised, all she did was hold the flexible line going to the spout, down under our 171's cabinet, and GENTLY tap the line multiple times as she shifted her hold to other points on the line.
Later, I am going to insert a soft iron wire that I have that just fits the hole on the spout in and see if that won't loosen up more of the deposit.
The screen on the end of the spout also needed cleaning, we did that first in hopes of solving the problem.
