JonsArt
Calendar Event: accessing valves, pumps, water heater Posted: 25 Nov 2017 at 9:35pm |
Just bought a new Rpod 180 about two months ago. I recently winterized it and had to remove the mattress and two boards the mattress lays on. These are difficult to remove without doing damage and almost impossible to find a place to put them while working on the system. I am thinking about modifying it to make it more accessible. I have some ideas but was wondering if anyone out there in Rpod land has done such a modification.
Posted: 25 Nov 2017 at 9:51pm |
I don't know where things are in a 180, but can you not access the water heater, etc., by unscrewing the kick panels in front of it, instead of attacking it from the top?
marwayne
Posted: 25 Nov 2017 at 11:22pm |
Jasp
Posted: 26 Nov 2017 at 7:18am |
I too have a 180, and getting access to the hot water tank and pump is a huge pain in the ass. I have seen where one owner put an access door on the outside of the pod. It was the perfect fix if you have the guts to cut into your pod. I have two small 2x4's that I use to prop up each piece of plywood and I leave the mattress on. Not the best idea, but it helps......except for the time it fell on me and just about cut me in half..
Paul
2016 Rpod 180
2014 Toyota Tacoma
wooleeman
Posted: 26 Nov 2017 at 8:58am |
Although I have a 179 I had a similar problem. I installed a piano hinge connecting the two pieces of plywood the length of the bed and use a prop rod to hold it up. I also had to make a notch on either end to pass over the curtain string holder. Seems to work ok.
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
Posted: 26 Nov 2017 at 3:33pm |
On my 177 I could barely access the 3 valves from underneath via the storage area; also you have to be a contortionist and weigh under 165 and not have a fear of small, tight areas to do this. After doing this the first time in November 2011 I took measurements and with a skill-saw CAREFULLY cut a 4" x 6" opening above the 3 valves. Now all I have to do is lift the mattress, slide open my 5" x 7" door, reach down, and turn the 3 valves.
NickLPod
Posted: 27 Nov 2017 at 9:21am |
We purchased our 180 in 2016. One of the first things I modified was the bed. Having noticed the support frame was screwed into the front wall (luan) & was loose, I added (glued & screwed) additional wooden rails & supports (using poplar 1x2 inch pieces). This allowed me to cut the 2 large boards into 6 independent pieces for easier access to the water pump (& storage areas) from above. Each board is held in place with 2 short screws. Worked great for winterizing last month here (up North)!
2016 R-Pod 180
2011 Audi Q5 3.2 V6
Wife Carole
Dog Corra
