  <title>R-pod Owners Forum : accessing valves, pumps, water heater</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : accessing valves, pumps, water heater</description>
  <pubDate>Thu, 24 Sep 2026 20:34:24 +0000</pubDate>
  <lastBuildDate>Mon, 27 Nov 2017 09:21:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=10954</WebWizForums:feedURL>
   <title>accessing valves, pumps, water heater : We purchased our 180 in 2016....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102442#102442</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5685" rel="nofollow">NickLPod</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 27 Nov 2017 at 9:21am<br /><br />We purchased our 180 in 2016. One of the first things I modified was the bed. Having noticed the support frame was screwed into the front wall (luan) &amp; was loose, I added (glued &amp; screwed) additional wooden rails &amp; supports (using poplar 1x2 inch pieces). This allowed me to cut the 2 large boards into 6 independent pieces for easier access to the water pump (&amp; storage areas) from above. Each board is held in place with 2 short screws. Worked great for winterizing last month here (up North)!]]>
   <pubDate>Mon, 27 Nov 2017 09:21:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102442#102442</guid>
   <title>accessing valves, pumps, water heater : On my 177 I could barely access...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102428#102428</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 26 Nov 2017 at 3:33pm<br /><br />On my 177 I could barely access the 3 valves from underneath via the storage area; also you have to be a contortionist and weigh under 165 and not have a fear of small, tight areas to do this.&nbsp; After doing this the first time in November 2011 I took measurements and with a skill-saw CAREFULLY cut a 4" x 6" opening above the 3 valves.&nbsp; Now all I have to do is lift the mattress, slide open my 5" x 7" door, reach down, and turn the 3 valves.&nbsp;&nbsp;]]>
   <pubDate>Sun, 26 Nov 2017 15:33:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102428#102428</guid>
   <title>accessing valves, pumps, water heater : Although I have a 179 I had a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102416#102416</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7582" rel="nofollow">wooleeman</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 26 Nov 2017 at 8:58am<br /><br />Although I have a 179 I had a similar problem. &nbsp;I installed a piano hinge connecting the two pieces of plywood the length of the bed and use a prop rod to hold it up. I also had to make a notch on either end to pass over the curtain string holder. Seems to work ok.]]>
   <pubDate>Sun, 26 Nov 2017 08:58:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102416#102416</guid>
   <title>accessing valves, pumps, water heater : I too have a 180, and getting...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102414#102414</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6170" rel="nofollow">Jasp</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 26 Nov 2017 at 7:18am<br /><br />I too have a 180, and getting access to the hot water tank and pump is a huge pain in the ass.  I have seen where one owner put an access door on the outside of the pod. It was the perfect fix if you have the guts to cut into your pod.&nbsp;&nbsp;&nbsp;I have two small 2x4's that I use to prop up each piece of plywood and I leave the mattress on.  Not the best idea, but it helps......except for the time it fell on me and just about cut me in half..]]>
   <pubDate>Sun, 26 Nov 2017 07:18:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102414#102414</guid>
   <title>accessing valves, pumps, water heater :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102413#102413</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1045" rel="nofollow">marwayne</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 25 Nov 2017 at 11:22pm<br /><br /><a href="https://postimages.org/" target="_blank"><img src="https://s7.postimg.org/brqk8vn3v/100_0148.jpg" border="0" /></a>]]>
   <pubDate>Sat, 25 Nov 2017 23:22:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102413#102413</guid>
   <title>accessing valves, pumps, water heater : I don&amp;#039;t know where things...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102412#102412</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 25 Nov 2017 at 9:51pm<br /><br />I don't know where things are in a 180, but can you not access the water heater, etc., by unscrewing the kick panels in front of it, instead of attacking it from the top?&nbsp; <br><br>TT<br>]]>
   <pubDate>Sat, 25 Nov 2017 21:51:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102412#102412</guid>
   <title>accessing valves, pumps, water heater : Just bought a new Rpod 180 about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102411#102411</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7878" rel="nofollow">JonsArt</a><br /><strong>Subject:</strong> 10954<br /><strong>Posted:</strong> 25 Nov 2017 at 9:35pm<br /><br />Just bought a new Rpod 180 about two months ago. I recently winterized it and had to remove the mattress and two boards the mattress lays on. These are difficult to remove without doing damage and almost impossible to find a place to put them while working on the system. I am thinking about modifying it to make it more accessible. I have some ideas but was wondering if anyone out there in Rpod land has done such a modification.&nbsp;<div><br></div><div>&nbsp;</div>]]>
   <pubDate>Sat, 25 Nov 2017 21:35:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=10954&amp;PID=102411#102411</guid>
