  New Posts New Posts RSS Feed: Self-Adjusting Brakes?
Topic ClosedSelf-Adjusting Brakes?
 Post Reply Post Reply Page  123 6>
Pod People View Drop Down
Direct Link To This Post Topic: Self-Adjusting Brakes?
    Posted: 01 Nov 2017 at 11:37pm
We use a temperature sensing gun for wheel bearings and brakes and tires. I look for differences between each side within the category( right vs left).  I think our tv brakes are usually a little warmer because they are discs instead of shoes. The pod tires are usually warmer because they are smaller diameter, thus more rpms. Bearings differences between the tv and trailer are also different- usually the pod is slightly hotter. Also the sunny side of bearings and tires will be warmer .
The temp gun really allows specific comparisons and you learn the normal trends afterwe wrote them down during a trip. We checked them every time we stopped. The gun came from Harbor Freight and was reasonably priced
Vann
Vann & Laura 2015 RPod 179
HARLEYULTRA View Drop Down
Direct Link To This Post Posted: 01 Nov 2017 at 3:27pm
The Lippert brakes are self adjusting when you stop going forward. A car is adjusted when you go back and apply the brakes. This is per Lippert
Subzilla View Drop Down
Direct Link To This Post Posted: 01 Nov 2017 at 8:37am
Chuck, I wondered the same thing...couldn't get the Pod brakes to lock up so were the brakes properly adjusted?  So I started doing what Mike suggested and it seems all is well.  On a separate issue I noticed, sometimes at a stop, the brakes feel like they stick when I begin to move forward again.  Wonder if that has to do with the FSA.
Mark
Concord, NC
2017 RP 179 "Podzilla"
2011 Silverado 1500 4X4
Direct Link To This Post Posted: 31 Oct 2017 at 6:03pm
+1 with Mike.
Direct Link To This Post Posted: 31 Oct 2017 at 5:55pm
I'm not a believer in the lock up method. I find a parking lot and out TV in drive, then adjust controller to where the truck in idle does not pull the TT forward, the TT brake stops it when controller brake is applied.
ChuckB View Drop Down
Direct Link To This Post Posted: 31 Oct 2017 at 5:08pm
I was worried because my 2nd-hand 2014 RP-178 wouldn't lock up (skid) the trailer brakes at 20 MPH whenever I would try to adjust my integral GMC Sierra brake controller like the GMC book advised.
I think that a lot of the aftermarket controllers advise the same (skidding) procedure for adjusting the controller.
I suspected that the reason the RPOD wouldn't skid was perhaps that the RPOD brakes were not self-adjusting and needed adjustment (which brought me to this forum).
I didn't inherit any literature from Forest River about the brakes, so I got the Dexter Axle serial number from the sticker on the axle and called Dexter's service contact number. They told me that my axle has Forward-Self-Adjusting  brakes which automatically adjust for brake lining wear (without braking in reverse). (Coincidentally, the initials "FSA" were also typed on the axle sticker)
Furthermore, they said that the brakes are designed not to skid and that Dexter wishes that the brake controller manufacturers would stop advising the 20 MPH skid procedure for brake controller adjustment.
It sounds like you are left to your own devices find a comfortable brake controller setting with these kind of brakes. I have been setting my GMC controler at 6.0 (out of 10) and it seems to brake the trailer OK. But to be honest, I can't sense much difference when I vary the setting.
I have made a habit of comparing (by feel) the temperature of my trailer brakes to my tow vehicle brakes. If the trailer brakes are hotter than the truck's, then I start backing-off the controller setting number until they both warm-up to about the same temperature. This is the best subjective measure  that I've come up with to adjust my brake controller.  I'm thinking of buying a temperature sensing  gun to keep my hands clean and be a little more methodical/scientific.
Rey View Drop Down
Direct Link To This Post Posted: 27 May 2013 at 8:12am
I did not want them altered, the dealer replaced the self adjusting brakes with new back plate, shoes and magnets, no charge.  I also replaced the knobby tires with smooth tread ones for better gas mileage.
bhamster View Drop Down
Direct Link To This Post Posted: 24 May 2013 at 9:05am
Originally posted by Rey
I have Lippert self adjusting brakes.  I am replacing them with Dexter 10x2 manual adjusted brakes
Sorry to hear that. Why not just disable the self adjusting feature instead of replacing the whole thing?
Rey View Drop Down
Direct Link To This Post Posted: 24 May 2013 at 8:54am
I have Lippert self adjusting brakes.  I am replacing them with Dexter 10x2 manual adjusted brakes for the following reasons.  They are impossible to get balanced braking, they do not share the braking equally.  The brakes alternated from one side to the other with 2/3 one side and 1/3 on the other.  There is possible drag on the side that got self adjusted last.  They cause sway due to uneven braking.  Check your wheels for the amount of brake and magnet residue on them after each trip, you may find one side has more than the other.  That was my first indication that the brakes were not sharing equally.  Take a temperature reading and compare the results.  When they are adjusted manually, you are confident that there is no drag, and get better gas mileage.
dsmiths View Drop Down
Direct Link To This Post Posted: 03 May 2013 at 8:54pm
I am guessing we have maybe 1000 miles on our pod since new. I pulled the rubber plugs and inspected the outer wheel bearing area, nothing but grease. I think it is wise to check but to repack wheel bearings every year is maybe unnecessary. Now if you are going across country and back, yes. Automobiles that have front wheel bearings that can be repacked such as a 1995 or so chevy pickup up truck the manufacture recommends every 30,000. miles. the wheel bearing loading on the pod is probably higher than passenger cars and needs to be checked periodically, if it makes you feel better to pack every year, it does no harm.
Dane and Donna Smith
2011 RP-172
lift kit
