  New Posts New Posts RSS Feed: winterizing
Topic Closedwinterizing - Event Date: 08 Oct 2017
marcagoddard View Drop Down
Direct Link To This Post Calendar Event: winterizing
    Posted: 08 Oct 2017 at 6:47pm
I can't find the lose hose to put into antifreeze for winterizing.  Can anyone help?  There is no lose hose so do i need to undo something?
Thank you so much for any help.
Marc Goddard
Marc Goddard
Direct Link To This Post Posted: 08 Oct 2017 at 7:27pm
Under your sink near the floor you should find a plastic 3-way valve.  One line comes from your fresh water tank, the one opposite that goes to your water pump.  The 3rd line is the one you are looking for, should be a short pigtail about 12 - 18 inches long.  AFTER turning your 2 or 3 valves on top of your hot water heater to bypass, turn that 3 way valve 1/4 turn (it only turns one way) and put the pigtail into your antifreeze bottle.  Turn on your water pump and open your faucets until the pink comes out.  You are done.  I have only done it once that way back in 2011 when we purchased our 177.  I didn't like the antifreeze taste the following spring.  Had to use a couple apps. of white vinegar and lemon juice to rid the lines of the smell and taste.  Anyway since 2012 I have only use air pressure to blow out my lines (this is year 6) and have had no problems and it only takes about 1 minute to clear the lines out.  I do use approximately 1 pint of antifreeze for the 2 sink and 1 shower trap and then a small amount on top of the toilet seal to keep the seal lubricated during those cold winter months.
Direct Link To This Post Posted: 08 Oct 2017 at 8:08pm
thank you so much! I will try.
Marc Goddard
Direct Link To This Post Posted: 08 Oct 2017 at 8:10pm
There is no third line under sink. I will keep searching! thanks again
Marc Goddard
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 08 Oct 2017 at 8:27pm
Are you looking down at floor level?  You have to unscrew the kick panel and look behind it (not in the cabinet under the sink -- below that).
DavMar View Drop Down
Direct Link To This Post Posted: 09 Oct 2017 at 9:55am
Marc Goddard
Unless I'm totally mistaken when I looked at my 180 model the pump and such is under the bed toward the back side on the left behind the hot water heater. It depends on the model you have I think? Confused
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Direct Link To This Post Posted: 09 Oct 2017 at 5:57pm
Dave, thanks for pointing that out, you are correct on the location of that hose for the 180.  I should have asked.  He didn't mention what model he had and is not noted in his signature line.  Hopefully he will let us know and if he does have the 180, he will locate it per your instructions.
kansasfrogs View Drop Down
Direct Link To This Post Posted: 09 Oct 2017 at 6:34pm
I was winterizing my 182 G and the antifreeze sprays out the city water inlet instead of the faucets! I tried pushing in the little white deal under the screen in the inlet, but it didn't make any difference.  How can I fix this.  Had no trouble with this before!!  Thanks.
FROGGY
Direct Link To This Post Posted: 09 Oct 2017 at 7:23pm
Now that's one unusual problem I would say. By chance did you NOT have a sink or shower valve open while you pumped the antifreeze into the system?
wonder dog.
2017 Rpod 180
Lexington, NC
Direct Link To This Post Posted: 10 Oct 2017 at 11:39am
Yea i found it behind the panel under sink at foot level! thanks forum! This works.
Cheers,
Marc
Marc Goddard
