  New Posts New Posts RSS Feed: 2019RPOD 191
2019RPOD 191
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Topic: 2019RPOD 191
    Posted: 10 Oct 2025 at 11:01am
+1 to StephenH also GG you got something in there that shouldn't be.  You just have to trace it down.
Jay
179/2019
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2025 at 10:19pm
Check to see if the prior owner put a jumper in the trailer's Bargman connector or put a jumper inline. Some people do that so that the outside lights on the trailer will be lit even when the trailer is not connected to the tow vehicle. I doubt it was a factory wiring flaw.
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2025 at 11:36am
Originally posted by D.PHILLIPS
Vehicle not connected to trailer.
Then you have a wiring issue in your Rpod. There is no connection between the running lights and the 12VDC in the trailer.
There are a couple of places where the wiring might get "close", but there is normally no connection.
To troubleshoot, I would look around the battery box, or underneath. The wiring from the Bargman should more or less go directly to the running lights. There is also a +12VDC wire in the Bargman that should go to the battery, so that is where the likely culprit is.
D.PHILLIPS View Drop Down
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 4:30pm
Doug Phillips
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2025 at 12:09pm
Bargman is the connector that connects between your trailer and your tow vehicle.
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 2:39pm
What is the Bargman connector and where is it? Thanks
Doug Phillips
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 12:50pm
Running lights are connected to the Bargman connector. There is some cross connection that should not be there. Try first to disconnect the Bargman and see where that goes.
However, my suspicion that your Rpod has a wiring error.
Post Options Post Options   Quote D.PHILLIPS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2025 at 12:14pm
First trip out with our 191. Her's my problems, when I hook up to shore power all my clearance lights and running light come on. Any idea how to turn them off. Have check and cannot find a switch to turn them off. Also, the TV ask for pass work to get programming.
Doug Phillips
