| Author |
Topic: New prospective owner needs inspection tips Posted: 30 Jun 2020 at 12:35pm |
If you want to do that you can but be sure that the surfaces you're applying the eternabond to are clean and properly primed, or you can wind up concealing a leak that develops later.
pdorazio
Posted: 30 Jun 2020 at 7:03am |
Thinking about preventatively applying endurabond tape to all top seams as soon as I find a clean unit. Thoughts??
Posted: 30 Jun 2020 at 6:31am |
Yep, water leaks are a major issue with travel trailers in general.
pdorazio
Posted: 30 Jun 2020 at 5:59am |
Great advice looking at another today. It seems so many get wet?
Posted: 30 Jun 2020 at 4:57am |
You can't really know how bad the leak got before it was repaired. There are lots of trailers out there, I'd pass on anything that has signs of water damage.
pdorazio
Posted: 29 Jun 2020 at 9:44pm |
Thanks just saw one. Had eternabond across rear seal and top left. A little bubbling in top left corner. No smell. Been pouring here so it would have been wet. Old damage I think. Question is will it continue to come apart?
crw8sr
Posted: 29 Jun 2020 at 7:53pm |
Water stains on the ceiling, walls, floors? Smells musty, moldy, Wet? Check in the corners, under the sinks and shower. Near the water pump and water heater, Windows and door frame.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
pdorazio
Posted: 28 Jun 2020 at 9:53pm |
Hi, we are looking at a used 182g and need tips on where to check for water damage or other issues. Any tips are greatly appreciated. Thanks. Pete
