Hello, winterizing for the first time.
I drained everything - fresh water, low point drains, hot water tank.
Sprayed out hot water tank for sediment.
Replaced all drain plugs.
Blew out entire system at 30 psi.
Now, I'm going to run antifreeze through system -
Closed hot water tank in and out, opened siphon line and inserted into 1 gallon of antifreeze.
Turned on pump, it sucked up about half of it.
Now when I open the valves on the kitchen sink, it is just a really tiny trickle of antifreeze, I was expecting it to flow like typical water and shut it off real quick.  The shower faucets and toilets flow well like I would expect.  Did I do something wrong?
