Post Reply
| Author | |
BostonBrianfromTulsa
Joined: 26 Jun 2016 Location: Oklahoma Online Status: Offline Posts: 3 |
Topic: Air conditioner / electricalPosted: 27 Jun 2016 at 8:11am |
I have a 2010 172 model that I've owned since it was new. Last year, I noticed the lights were dimming while we were plugged in. I assumed it was the converter but didn't do anything with it at the time. As I've pulled it out of storage this week, The air conditioner blower starts ok, but bogs down to a stop after 30 seconds. Any suggestions?
The mind is not a vessel to be filled, but a fire to be kindled.
Joined: 25 Jul 2011 Location: Central KY Online Status: Offline Posts: 6128 |
Posted: 27 Jun 2016 at 8:33am |
Well.. the lights are on the 12v system, and the a/c on the 120v, so not directly related. But yes the converter is on the 120v system. Using a multimeter, check the converter output. A/C sounds like the blower motor itself. Is the compressor kicking on?
Posted: 27 Jun 2016 at 8:57pm |
Thanks for replying furpod! Compressor comes on, all other electrical seems to work OK. AC input to fuse panel looks good and output to Air is OK. I just didn't expect to have to change out the blower motor after just 5 years. Is there a quieter version I can replace it with?
Posted: 27 Jun 2016 at 10:11pm |
Not that I am aware of. At least not without changing the whole thing. I know the Polar Cub 9.5 is a much quieter unit. But it's +$700 to swap out, plus labor if an owner can't do it themselves.
Posted: 27 Jun 2016 at 10:15pm |
Pull the cover off the unit and see if anything inside could be causing this problem before you go and get a replacement. It could be something got in there that shouldn't be there. OTOH, it could be that the blower motor bearings are bad. It might be worth getting it checked out to see what the actual problem is.
Posted: 27 Jun 2016 at 10:35pm |
Took it all apart, found that the plastic squirrel cage had motivated itself into housing. The bearings on the motor feel fine, several loose nuts and bolts up there. This thing is a pain to work on -Definitely not designed with service in mind. I'm going bank on it being cool up in Rocky Mountain National Park next week and not worry so much about the Air Conditioner right now.
Thanks for the comments all!
Podster
Joined: 16 Sep 2014 Location: San Antonio Online Status: Offline Posts: 1108 |
Posted: 28 Jun 2016 at 6:33pm |
First thing that came to mind after I read your post was grounding. I believe a loose, damaged, or corroded ground point would contribute to both of the POD systems.
Cliff & Raelynn
Post Reply
