Post Reply
| Author | |
GlibGuy
Joined: 14 Apr 2015 Location: Virginia Online Status: Offline Posts: 65 |
Topic: DOOR Hard to Open and LatchPosted: 18 Apr 2016 at 1:49pm |
The door on our 178 is difficult to open and difficult to get to latch when you pull it from the inside. Seems like it's something to do with the screen door sticking and then the main door sticking to it(?).
Pushing on the door while you pull the latch to open makes it easier to open. You have to "slam" when pulling from the inside.
Anyone been through this issue? I've thought about taking the door keeper off and grinding on it, etc., but I don't really feel that's the problem. |
MICK
Posted: 19 Apr 2016 at 8:45pm |
I'm sure you just need to adjust the latch plate.
Moving to the pod section.
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6463 |
Posted: 19 Apr 2016 at 9:33pm |
Also, spray a little silicone or teflon lubricant on the latch and latch plate. That seemed to help me. I didn't have to adjust the latch plate.
sailor323
Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 01 May 2016 at 11:44am |
One other thing, on the bottom of the door, there is a small, wedge shaped nylon or plastic thing that brings the door into alignment with the door frame when closing. On our pod, this piece became somewhat dis-attached and was hanging by a sliver. When we tried to close the door, it would jam against the frame, making it difficult to close the door. I put a piece of double stick tape between it and the door to fix the problem. We do have to use silicon lubricant on the latch mechanism from time to time
JHoffman
Joined: 06 Mar 2016 Location: Westfield, MA Online Status: Offline Posts: 82 |
Posted: 01 May 2016 at 2:36pm |
When we picked up our pod I could hardly get the keys to unlock anything and the door latch was hard to work. A good shot of lube did a world of good. I don't think FR lubes anything before they go out the door.
2016 176t Rpod the "Hoffpod"
2010 Toyota Tundra 5.7L |
CharlieM
Joined: 23 Nov 2012 Location: N. Colorado Online Status: Offline Posts: 1797 |
Posted: 01 May 2016 at 3:22pm |
Seems like Jim's Law applies.
If it moves and shouldn't: Duct Tape If doesn't move and should: WD40 |
Retroactive
Joined: 15 Mar 2016 Location: Bolton, MA Online Status: Offline Posts: 270 |
Posted: 01 May 2016 at 3:32pm |
I had the exact same problem when I received my pod. I used Dry Lock Lube, which is available at Walmart. Hit all the moving parts, including a shot into the key holes. Mine works like a champ now.
Post Reply
