  New Posts New Posts RSS Feed: Bathroom door issue
Topic ClosedBathroom door issue
pnwcamper View Drop Down
Direct Link To This Post Topic: Bathroom door issue
    Posted: 14 Feb 2016 at 9:19am
The top half of my bathroom door on my 2014 177 is rubbing against the door frame, there is plenty of room from the door nob down to the bottom of the door.
I suppose I could plain down the door but curious if anyone else has an idea? Btw, all the hinge screws are tight.
Thanks
2014 R-Pod 177
2009 Toyota Tacoma Access Cab 4.0 V6
Direct Link To This Post Posted: 14 Feb 2016 at 11:11am
Ours warped slightly, outward like yours but not towards the frame.  Probably particle board which may not plane well.
ron_whitt View Drop Down
Direct Link To This Post Posted: 14 Feb 2016 at 11:38am
I used to work at a place where I put together pre-hung interior doors. Try putting a small shim behind the bottom hinge, that will draw the top of the door away from the door frame. Sometimes that will help.
Ron & Shirley
2020 Tacoma
2012 177 rpod
codycountry View Drop Down
Direct Link To This Post Posted: 14 Feb 2016 at 11:41am
Same thing on my 2013 177.  It was the plastic molding that needed fixing.   All it took to fix it was some good glue behind the plastic trim to suck it over tight against the wall jamb.  Glue and shim it tight away from the  the door until it's set up and dry,  to create a 1/4 or more gap so the door isn't hitting it.  That ought to fix the problem.
Direct Link To This Post Posted: 14 Feb 2016 at 2:08pm
    If the above ideas do not help and if you have a bar clamp that you can reverse and use to spread the door opening near the top that may help. When we had our r-pod the back window was difficult to slide open or close I used a bar clamp to expand the opening and it helped. You just need to be careful not to expand it to much but the walls and framing will have a little give without doing any harm.
2014 Ram 1500 Quad cab
Podster View Drop Down
Direct Link To This Post Posted: 14 Feb 2016 at 9:34pm
Yes, same here on the 178. I pulled the door off and trimmed it some and refinished it. No biggie.
Cliff & Raelynn
Ranger 4.0/178
