  New Posts New Posts RSS Feed: Ext Molding
Topic ClosedExt Molding - Event Date: 15 Jun 2013
hogone View Drop Down
Direct Link To This Post Calendar Event: Ext Molding
    Posted: 15 Jun 2013 at 7:05pm
Hopefully someone will understand what I'm trying to describe, not sure what to call it!!!  It is rubber molding that goes from the very back bottom to the very front bottom on both sides and follows the curvature of the pod along the top.  It fits in a channel the entire way.  It appears to be (possibly) some sort of rubber molding that covers screws. Well long story short, mine is cracking on one section, very brittle.  Anyone encounter this?  Sorry if my description is poor! hogone
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
2017 HD Streetglide
CHEESEHEAD
Sleepless View Drop Down
Direct Link To This Post Posted: 15 Jun 2013 at 8:22pm
Those strips are just as you described.  They are vinyl trim strips that are used on almost all RVs to cover the corner screws and improve the appearance of the metal strips.  The vinyl trim comes in several widths and are readily available from RV supply stores and on eBay.  They are relatively inexpensive and very easy to replace.  Normally, the strips will last almost indefinitely.
In your case, they should be covered by your warranty.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
Direct Link To This Post Posted: 15 Jun 2013 at 9:00pm
Your right, vinyl trim stripsEmbarrassed.  I will inquiry into replacements.  Thanks a lot.
Jon & Pam
2025 GD 17MKE
2023 F150
2017 HD Streetglide
CHEESEHEAD
