| Author |
TerryM
Topic: 12v Systems Posted: 18 Mar 2011 at 7:33pm |
Did you know that if your 12v system goes out you loose: lights, fan, furnace and the fridge. EVEN WHEN HOOKED UP TO 110v! I found out the hard way. In the breaker box there are 2 large fuses. These protect your system from hooking up the battery wrong. I did! Just a spit second and poof. Both fuses went. I forgot all about that until the lights started getting dim and the fan slowed down. So I shut off the lights, fan and the TV amplifier thinking everything was shut off. The furnace wouldn't come on (58*)! Then I noticed the fridge shut off and wouldn't come back on. CRAP! No heat and I forgot to bring a pillow. So I had to use my 1 and only blanket as a pillow. No problem I went to sleep dressed...including my jacket! In the morning I got new fuses and 2 extras! But, I did have a good time camping and showing the Pod to people.  Terry
Pawpod
Posted: 18 Mar 2011 at 8:22pm |
 Note to self! Pack spare fuses. Glad it turned out ok.
Ready to pod around!
rpodcamper.com
Posted: 18 Mar 2011 at 10:55pm |
Sounds like a fun camping trip! 58 is cold?
tpierce220
Posted: 18 Mar 2011 at 11:21pm |
Right now 58 sounds like a heat wave.
Goose
Posted: 19 Mar 2011 at 2:40am |
Now thats one tough camper. I believe that I would have been in the TV with the seat layed back, engine running with the heat on. Goose
TerryM
Posted: 19 Mar 2011 at 3:55am |
Considering that the daytime temps were close to 80* it was cold at 58*.
Terry
Guests
Posted: 19 Mar 2011 at 5:41am |
Sorry to hear about the problem  . Yep, the 12v stuff always runs on 12v. When hooked to commercial power, the 12v is supplied by the power supply located behind the distibution panel (where the circuit breakers and fuses are). When not hooked up, it comes from the battery.
You might want to do a simple test to make sure the power supply wasn't damaged in the reversed polarity. Unhook the battery and then plug into 120v power and make sure the 12v stuff still works. Hopefully the fuses did their job fast enough that no damage was done. Even if the power supply is broke, the 12v stuff will still work off of the battery....until it runs down.
TerryM
Posted: 19 Mar 2011 at 2:51pm |
Everything worked after I put new fuses in. I was surprised that the fridge wouldn't when the battery went dead. The battery charged up easily.
Terry
Guests
Posted: 19 Mar 2011 at 4:39pm |
Terry
Great!  Glad there was no damage. I think the fridge needs power (from some source) to run the "brains", unlike say, the water heater; which has no electronic brain.
TerryM
Posted: 19 Mar 2011 at 6:15pm |
Neither do I!  Terry
