  New Posts New Posts RSS Feed: Fiberglass oxidation
Jenga Jack View Drop Down
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Topic: Fiberglass oxidation
    Posted: 20 Apr 2026 at 2:51pm
The front of our R-Pod had oxidation from too much sun. I've removed it with a McGuires product. Any suggestions on wax/sealant to use to protect the "raw" fiberglass? And best way to apply?
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 3:27pm
Most any car wax will work. I used a Meguiar's wax after I removed the oxidation. Some folks swear by ceramic coatings.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 8:08pm
Agree with gpokluda.  I use Meguiar's Ceramic on my 177.  Does a fantastic job, leaves a finish that is 'baby butt' smooth and shiny as well.
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2026 at 8:13pm
Thank you Podders, I will give it a try.
GlueGuy View Drop Down
Post Options Post Options   Quote GlueGuy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2026 at 2:06pm
For the record, it's not actually fiberglass, but the gel coat.
The Meguiars is still a good solution.
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 1:56pm
I just Googled Meguiar's Ceramic and results gave a variety of options, all containing the word Ceramic in the description. Did you find any specific one the worked well? This will be the first application after removing the oxidation.
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2026 at 5:33pm
After I removed the oxidation, I used Mequiar's Mirror Glaze, only because I had a bunch of it. Once I used that up, I bought some Meguiar's Hybrid Ceramic Spray Wax.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2026 at 5:24pm
This product used to come in a florescent green bottle, but the last couple of years it now comes in a blue spray bottle.  Works great!  First app. (do this out of the sun in the shade) with the surface wet, lightly spray on (don't allow to dry) and wipe off.  2nd app. lightly spray on surface and hose off with a stream of water then dry off with a clean towel.  Simple and gives a great finish.
IL-Podders View Drop Down
Post Options Post Options   Quote IL-Podders Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2026 at 4:06pm
What did you use to eliminate the oxidations?
Marv-N-Kathy
2015 179 RPod
2016 Chevy Tahoe
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2026 at 8:41pm
I used Meguiar's #50 Cleaner Wax for RVs and Boats. My oxidation was light. They sell heavier duty products for heavy oxidation.
Gpokluda
2022 Escape 5.0TA
Honda SCL500
