2019 RPOD 191 Hood River |
Post Reply
| Author | |
D.PHILLIPS
Joined: 17 Aug 2025 Location: Perryville,MO Online Status: Offline Posts: 22 |
Post Options
Quote Reply
Topic: 2019 RPOD 191 Hood RiverPosted: 18 Oct 2025 at 10:06am |
RPOD at RV repair shop for electrical issue. When connected to 110 power the all the clearance lights and taillight s come on. During trouble shooting he discovered when the AC is turned off the lights go off. Anyone had this problem with their RV or any suggestions that I could provide to aid in the trouble shooting. He believes there may be a screw or staple that has pierced the wires some where the AC wires run.
Doug Phillips
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 496 |
Post Options
Quote Reply
Posted: 19 Oct 2025 at 7:13am |
Did it just start doing this or has it done it all along?
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
D.PHILLIPS
Post Options
Quote Reply
Posted: 19 Oct 2025 at 9:08am |
I am the new owner and found the problem when I plug in the RPOD at the campground. The previous owner did not say anything about the issue.
Doug Phillips
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Post Options
Quote Reply
Posted: 19 Oct 2025 at 12:00pm |
The AC runs on 110VAC, so if it was an AC wire that was cross connected, I would expect it to just blow out the LED running lights. So I'm going to guess it is cross-connected with the thermostat, which is probably around 12V, which wouldn't kill the LED running lights.
If you can find the transformer for the thermostat, you might try disconnecting that to see what happens.
D.PHILLIPS
Post Options
Quote Reply
Posted: 23 Oct 2025 at 2:57pm |
Got text from my RV repair service yesterday stating he found the electrical issue. It was staples thru the wires in the ceiling. Great news.
Doug Phillips
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3436 |
Post Options
Quote Reply
Posted: 04 Nov 2025 at 7:24pm |
Glad you got a knowledgeable person to find and repair your issue!
D.PHILLIPS
Post Options
Quote Reply
Posted: 04 Nov 2025 at 7:39pm |
Me to, thanks.
Doug Phillips
poohbill
Joined: 22 Aug 2019 Location: Idaho Online Status: Offline Posts: 140 |
Post Options
Quote Reply
Posted: 08 Nov 2025 at 12:13pm |
We developed a water leak in the floor after years of use. Turned out to be a screw tip that eventually worked through a waterline. Of course, it was in the very last run I traced, in one of the most inaccessible.
2016 179 Gastropod
2017 Ridgeline |
D.PHILLIPS
Post Options
Quote Reply
Posted: 08 Nov 2025 at 12:34pm |
My issue was a screw holding the solar connector on the roof had entered the yellow power wire between the ceiling and the roof. I took a while for RV service guy to find it. All he had to do was back the screw out and it released the wire.
Doug Phillips
Post Reply
