  New Posts New Posts RSS Feed: Jenson Stereo keeps turning on.
Topic ClosedJenson Stereo keeps turning on.
Vic/Frank View Drop Down
Direct Link To This Post Topic: Jenson Stereo keeps turning on.
    Posted: 19 Oct 2020 at 11:03pm
We are having problems with our Jenson stereo system coming on by itself in our driveway. I do use the Bluetooth for my Spotify pairing from my phone when we are camping but the radio seems to be coming on by itself. Has anyone had this problem?
Frank & Vicki
Colt View Drop Down
Direct Link To This Post Posted: 20 Oct 2020 at 12:38am
Hmmm. Are the batteries in the remote dying? Do you have mischievous children?
John
'16 R-Pod 180
Direct Link To This Post Posted: 20 Oct 2020 at 8:05am
It has an alarm function.. Make sure the alarm isn't on...
mhfnet View Drop Down
Direct Link To This Post Posted: 20 Oct 2020 at 11:50am
Unless the on/off button is red it is not off. Also switch the function to something other than BT (bluetooth) then off to see if that helps (might be a glitch). I do know it does stay on standby even when off which annoys me because it was draws current and still I do a lot of dry camping I want to keep stuff like that to a minimum so I installed a toggle switch in the power feed to really turn it off.
Direct Link To This Post Posted: 20 Oct 2020 at 12:55pm
Mischievous children are grown up. Big smile
Frank & Vicki
Direct Link To This Post Posted: 20 Oct 2020 at 1:00pm
Alarm is off. We did not get any manuals with our 183g but I have found one online for the Jensen. I think it has to be the bluetooth also. As soon as I go in there with my phone it connects to Spotify and starts playing even though Spotify app is not up on my phone. I will check for the red button for off. Toggle switch sounds good.
Frank & Vicki
Direct Link To This Post Posted: 20 Oct 2020 at 1:26pm
Sounds like you have autoplay turned on in your Spotify app. I had the same issue with my car bt. This explains how to shut autoplay off:
https://community.spotify.com/t5/Android/Option-to-disable-autoplay-on-bluetooth-connect/td-p/4748769
Pod People View Drop Down
Direct Link To This Post Posted: 20 Oct 2020 at 5:10pm
I also installed a simple on/off toggle switch.  I pulled the unit out of the wall and found the red 12V power wire and cut it, added a pigtail to each end and connected the toggle.  Now, I can completely turn the power off and save the battery.
Vann
Here is a picture-the white rod is a curtain rod separating the bed area
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 20 Oct 2020 at 6:09pm
So I disabled the auto connection on my phone an hour ago. I just went into the R-Pod and the news was on. When I turn it off there is no red light. Mine is a 2016 unit. I don't get it.
Thanks for the idea of the toggle switch.
Frank & Vicki
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 25 Oct 2020 at 9:44am
A main battery disconnect switch solves all nuisance power vampires. Propane detector, radios, voltmeters, 12v to USB adapters, etc.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
