Post Reply
| Author | |
Poddy
Joined: 22 Jul 2020 Online Status: Offline Posts: 47 |
Topic: The heater in a 2011, RP172Posted: 17 Aug 2020 at 7:23pm |
I folks, i don't have an issue or problem with my my heater. but i had to use it last Saturday night for about 10-20 min. to warm up the inside before bunk down. I was wondering, does the heater run on battery or propane or a combination of both? I was disconnected from shore power/ generator so it had to be one of the other two sources.
2011 RP172
2015 Toyota Tacoma Newfoundland, Canada |
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6483 |
Posted: 17 Aug 2020 at 7:28pm |
Okay. The heater uses 12V power for the fan. It requires propane to generate the heat.
Poddy
Posted: 17 Aug 2020 at 7:31pm |
Thanks StephenH. I was thinking that too, first time RV'er using the heater for the first time.
2011 RP172
mjlrpod
Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
Posted: 18 Aug 2020 at 11:33am |
Using the heater when not connected to shore power is probably the biggest battery draw. It's hard to get more than 2 days off a single 12 volt battery in colder temperatures.
2017.5 Rp-172
Pod People
Joined: 22 Sep 2011 Location: Chapel Hill,NC Online Status: Offline Posts: 1095 |
Posted: 18 Aug 2020 at 11:39am |
I would add that since you were not connected to power, the heater is the biggest user of battery power. The propane will last a long time, but the battery usage is the bigger concern when boondocking. Vann
Pod People
Posted: 18 Aug 2020 at 11:40am |
oops sorry MJLRPOD, didn't mean to step on you-guess we were typing at the same time Vann
Post Reply
