| Author |
yogamoment
Topic: tires Posted: 12 Jul 2020 at 1:47pm |
Heidi Schultz
yogamoment
Posted: 12 Jul 2020 at 1:48pm |
There has been a concern with the tires on R-Pods that they have a lot of blow outs. Is there any concerns with the 225/75 R ones on the 2020 171 ? We just bought a new R-pod and feel like I should replace them? Heidi
Heidi Schultz
Posted: 12 Jul 2020 at 2:26pm |
Need a little more information. What is the full label on the tires? Are they ST tires? Wheel size? Load range? Speed range if listed? Manufacturer?
mjlrpod
Posted: 12 Jul 2020 at 3:13pm |
I personally do NOT need anymore information. It's a fairly accepted fact that R-pods (and many others) come with crappy inferior tires, and I would recommend changing them out immediately. I have gone from the dealership to the tire shop for new tires on both of my new pods. When you have only one axle, what you put on there really matters. It'll cost you about 200 dollars to put a good set of carlisle radial tires on. Just one blow out of the inferior tires will cost over 500 dollars with the new fender, towing, new tires, new rim ETC...
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 12 Jul 2020 at 4:11pm |
I would have said the same thing last year but we recently had a post from one new owner who had OEM tires which were 15 inch LRD's with a 2500 lb rating IIRC. So, hopefully FR has addressed this issue now.
Pod_Geek
Posted: 13 Jul 2020 at 1:12pm |
Originally posted by offgrid
I would have said the same thing last year but we recently had a post from one new owner who had OEM tires which were 15 inch LRD's with a 2500 lb rating IIRC. So, hopefully FR has addressed this issue now. |
Our 2020.5 195 came with 15-inch ST 235/75s LRD rated at 2910 lbs (single axle). Speed rating 75 MPH.
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
Posted: 13 Jul 2020 at 2:47pm |
Pod_Geek, your tires sound good, buy you have a heavier trailer with a 4400 lb rated axle. So we still need to know what the OP's tires are rated for.
Pod_Geek
Posted: 13 Jul 2020 at 4:50pm |
Pod_Geek, your tires sound good, buy you have a heavier trailer with a 4400 lb rated axle. So we still need to know what the OP's tires are rated for. |
Of course. I was just adding a data point that agrees with your recollection to make you seem even wiser.
2018 RAM 2500 6.4L
Posted: 14 Jul 2020 at 6:40am |
Of course. I was just adding a data point that agrees with your recollection to make you seem even wiser. |
Okie1941
Posted: 24 Jul 2020 at 10:25am |
Originally posted by yogamoment
The asphalt highway in the sun is over 140 today. Temperature and speed causes tires to blow. Get the best tires you can and add metal stems and a Tire Pressure Monitoring System (TPMS). I will carry a DeWalt inflator and check tires every morning. I also watch pressure on TPMS and let air out during the day as it improves , ride, handling and safety. It's a science and includes measuring the weight on each wheel and adjusting pressure accordingly.
