| Author |
snorris
Topic: Water Tank Posted: 29 Aug 2017 at 6:06pm |
Thinking about the 180 as my first time purchase. Just me and once in a while one other person. I see on the forums there has been problems with the water tank coming loose or breaking when being hauled down the road full. Most of my camping is done in forestry camp grounds, blm land, out in the desert etc. where I am often long way from water. Can not imagine they would build something where you could not fill the tank and go. Is this a valid concern? Hate to by it and then have to add to tank supports. Any advice appreciated.
Posted: 29 Aug 2017 at 6:18pm |
I cant speak for 180s. On my 178 I reinforced the tank rails with bolts vice sheet metal screws. I'm happy.
snorris
Posted: 29 Aug 2017 at 6:29pm |
They secured the tank rails with sheet metal screws??? If I buy the 180 I will replace with stainless bolts and fiber lock nut. Thanks for the heads up.
Posted: 30 Aug 2017 at 7:15am |
I think standard they were 1"X14s. I replaced the screws I left with 11/4", DO NOT OVERTIGHTEN. I added 1 bolt to every bracket, which also pulled them flush against the rails. I would at least check and ensure the brackets are flush against the frame rails.
Winterpod
Posted: 30 Aug 2017 at 8:48am |
+1
DavMar
Posted: 30 Aug 2017 at 9:58pm |
Originally posted by mcarter
I think standard they were 1"X14s. I replaced the screws I left with 11/4", DO NOT OVERTIGHTEN. I added 1 bolt to every bracket, which also pulled them flush against the rails. I would at least check and ensure the brackets are flush against the frame rails. |
Photos???? A picture would be worth a thousand words.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Posted: 31 Aug 2017 at 8:10am |
I gave up on photos for this forum. A physical inspection will be self explanatory. Look at the one rail on each tank that is not welded to the frame rails. Ensure the screws are not loose and the tank rail is flush to the frame rail.
snorris
Posted: 01 Sep 2017 at 1:51pm |
Thanks to all for the info. If I purchase the RPOD will fix the tank problem and take care of some other options I have in mind.
Keith-N-Dar
Posted: 01 Sep 2017 at 5:15pm |
This is hardly a universal problem with pods. A few have had trouble, but mfar from all. If you are getting a new one it should be easy to have the dealer check the mount and repair as required. If they are not willing get another dealer.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
snorris
Posted: 01 Sep 2017 at 5:44pm |
That was my take also. Figure you can not ask to many questions.
