  New Posts New Posts RSS Feed: Water Heater only getting warm
Topic ClosedWater Heater only getting warm
troutpodder View Drop Down
Direct Link To This Post Topic: Water Heater only getting warm
    Posted: 19 Jun 2017 at 10:47am
Hey All,
Enroute to Alaska with the POD. Its already a great trip. Question. Our hot water heather does not seem to be heating the water to as warm of a temp as is used to do. We have been letting it run for 30-45 minutes and it only comes out lukewarm whereas in the past it came out hot to the touch ... ideas?
Troutpodder
TheBum View Drop Down
Direct Link To This Post Posted: 19 Jun 2017 at 11:12am
Did you remember to reconfigure the valves when de-winterizing?
Direct Link To This Post Posted: 19 Jun 2017 at 11:23am
yup.. it has worked since we de-winterized the unit
Direct Link To This Post Posted: 19 Jun 2017 at 11:40am
Sounds like to valve isn't quite turned all the way or you might have blown the water heater elemoent. Can get them at Lowes pretty cheap.
Rodncerita View Drop Down
Direct Link To This Post Posted: 19 Jun 2017 at 2:33pm
Are you using the electric element or the gas? Suggest using the gas (if not already) to see if desired temp is achieved. If water gets hot then a pretty good chance that your element is shot. If water is still Luke warm, then the cold water side is mixing with it somewhere. Most likely a valve.
Hope that helps.
Rodncerita
2017 R-Pod 179
2016 Ford Explorer
jimandclare View Drop Down
Direct Link To This Post Posted: 19 Jun 2017 at 2:38pm
Check to make sure the outside shower valves are completely shut off. Leaving them open allows the hot and cold water to mix.
Jim & Clare
2016 R-pod 178
2014 Ford Edge
Direct Link To This Post Posted: 20 Jun 2017 at 10:59am
I was just about to post this. I read about it on Facebook, I think. In that case, the valves were wide open but the cutoff switch on the shower head was engaged.
