  New Posts New Posts RSS Feed: Electric heaters
Topic ClosedElectric heaters
Direct Link To This Post Topic: Electric heaters
    Posted: 17 Nov 2009 at 10:19pm
When you are camping with full hookups, take advantage of the 2 inches of insulation on your 'pod and use a small electric space heater.  Unless its well below freezing you won't even need to turn it above low (750 watt setting).  I don't recommend an $18 model with a dial thermostat.  They don't have good temperature control.  I do recommend moving up to the $30 range and get one with a digital thermostat.
yizit View Drop Down
Direct Link To This Post Posted: 18 Nov 2009 at 12:46am
We have had both and ended up with the dial type only because of the small size.  Once you find the "right" spot mark it with a magic marker.
Former owner of 2009 172
Darlene & Jim, Ewok our Lhasa
Direct Link To This Post Posted: 18 Nov 2009 at 8:25am
Welcome to "the other side", yizit!
Direct Link To This Post Posted: 18 Nov 2009 at 9:58am
Glad to be here.
