Air Conditioning |
Topic: Air Conditioning Posted: 27 Sep 2015 at 9:06pm |
You can do it at home, but it will be easier with two people. The hardest part of installing a RV A/C is cutting the hole and running the wiring, but that is already done.
FL RPOD
Newbie Joined: 08 Sep 2015 Location: SW Florida Online Status: Offline Posts: 13 |
Posted: 27 Sep 2015 at 4:38pm |
Does anyone have any experience with what is involved or how hard it is to swap in a Coleman-Mach 8 Cub AC (or any brand for that matter) to replace the stock Demetic? Is it a home project or a professional dealer installation?
Posted: 19 Sep 2015 at 8:33pm |
And since it would run a bit longer on each cycle it will pull more humidity from the air. One of the downsides to using a 13.5k or 15k btu A/C in the pods is they cycle on/off too quickly. Humidity is more important for comfort than actual air temperature.
WillThrill
Senior Member Joined: 04 Jul 2014 Online Status: Offline Posts: 298 |
Posted: 17 Sep 2015 at 11:03pm |
If I were to replace our stock Dometic AC, it would probably be with the Coleman-Mach 8 Cub AC. It draws 1550 watts at 100 degrees Fahrenheit, and the startup draw doesn't seem to be too bad from reports I've read, especially with a good hard-start capacitor. A 2k generator would probably run it just fine, and heavens knows it would have to be much quieter than the 13.5k BTU Dometic. |
2014 Hood River 177 2005 GMC Envoy XL |
Grandpa Hiker
Senior Member Joined: 04 Jan 2015 Location: Martinsville, V Online Status: Offline Posts: 143 |
Posted: 17 Sep 2015 at 12:12pm |
Thanks for the link. It was a very interesting read.
Rob & Becky
2014 Ford Explorer 3.5 SOHC V6 2015 R-179 Pod aka Piddle Pod "Life is not about waiting for the storms to pass, it is about learning to dance in the rain!!" |
Posted: 16 Sep 2015 at 8:05pm |
I looked at that a long time ago. Basically just a converted window air conditioner for way too much money. See the thread below. The specific post I linked to shows steps I took to make the factory A/C quieter, but if you go back to page 1 and read through you'll see a range of options I explored in place of the factory A/C.
Grandpa Hiker
Posted: 16 Sep 2015 at 4:33pm |
Has anyone ever considered this as an alternative to the roof mounted Dometic that is way to loud?
Rob & Becky
