  New Posts New Posts RSS Feed: Removing window valance
Topic ClosedRemoving window valance
Travelcottage View Drop Down
Direct Link To This Post Topic: Removing window valance
    Posted: 12 May 2015 at 12:20pm
Anyone know how the window valances come off? I know they're screwed in place just haven't figured out where or how to access ....
Thanks
Cheri
Direct Link To This Post Posted: 12 May 2015 at 12:39pm
There are a couple methods they use. You may have "L" brackets inside the valance, you may have screws through the valance and into the walls, hidden under the fabric of the valance..
Podster View Drop Down
Direct Link To This Post Posted: 12 May 2015 at 6:44pm
furpod is correct, the valance is screwed directly into the wall through the fabric. Check the 90 degree folds on top and in the crevice of the fabric below. Probe around using the tip of a cross tip screw driver. Good luck!
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 12 May 2015 at 8:16pm
edit:  removed a ton of code.  didn't see any actual post - techntrek
