Hot water mixing with cold - Event Date: 28 Feb 2015 - 28 Mar 2015 |
Calendar Event: Hot water mixing with cold Posted: 01 Mar 2015 at 6:54pm |
Moving this over to the pod section.
Tars Tarkas
Posted: 28 Feb 2015 at 10:06pm |
This is pretty crude, but maybe it helps. The valves are the thin black lines. In the summer, cold water flows into the water heater and hot flows out.
In the winter, you cut the water heater out of the plumbing circuit. You can use cold water without filling and having to re-drain the water heater to re-winterize, or, more likely, you can just drain the water heater for the winter and run anti-freeze through the rest of the plumbing. This lets the you bypass the water heater, thereby saving about 6 gallons of antifreeze. You don't need antifreeze in a water heater that can be emptied and bypassed. Aside from the cost of 6 gallons of antifreeze, it may not be good for the water heater, I don't know, but flushing the antifreeze from the water heater would be too much trouble too. TT |
FJ Cruiser |
johnandwendee
Newbie Joined: 11 Mar 2014 Location: Ontario, Canada Online Status: Offline Posts: 35 |
Posted: 28 Feb 2015 at 6:49pm |
All responders... THANKS!!!!!! My technical wife follows this forum and remembered something about hot/cold mixing. I put out the question and your answers were really fast. Thanks again. John
John and Wendee
Bracebridge, Ontario Canada |
Outbound
Posted: 28 Feb 2015 at 6:25pm |
And sometimes it happens when you're not a newbie as well
Podster
Posted: 28 Feb 2015 at 5:45pm |
Ditto...
Cliff & Raelynn
CharlieM
Posted: 28 Feb 2015 at 5:33pm |
Exactly. Happens to most newbies at least once.
Tars Tarkas
Posted: 28 Feb 2015 at 5:27pm |
It sounds like the valve between the input valve and output valve at the water heater is open. There are 3 valves at the water heater. The one in the middle should be closed and the others open when using the water heater.
TT |
FJ Cruiser |
johnandwendee
Posted: 28 Feb 2015 at 5:10pm |
We have just started our second r.pod trip. It looks like (not sure yet), the hot water is mixing with the cold because it is lukewarm. Perhaps we turned one valve too many when we winterized in November or when we opened things up today. We think we saw a similar problem on this site awhile ago but we can't find the answer. Suggestions?
Thanks John |
John and Wendee
