  New Posts New Posts RSS Feed: beeping and red light flashing
Topic Closedbeeping and red light flashing
grandma20 View Drop Down
Direct Link To This Post Topic: beeping and red light flashing
    Posted: 04 Aug 2014 at 2:27pm
something is beeping under our dinette"bed" in our 177. There is a flashing red light where tthe fuses are located . We have no lights in the pod but the refrigerator is running fineon propane. What is causing the beeping and flashing re light. We know something is wrong but we dont know what. We are in canada heading to maine way home to Iowa. Long way to g o
Judy
Direct Link To This Post Posted: 04 Aug 2014 at 4:41pm
The LPG detector is under the dinette.  If you have no lights elsewhere in the pod the LPG detector is probably giving you a low voltage warning.  Your +12 connection in the Bargeman (7 pin) connector may either not be connected or has wiring that is too small, so it isn't charging your battery while you drive.  If you've been plugged in to a power pole at a campground then you may have a problem with the converter not charging the battery properly.
Direct Link To This Post Posted: 04 Aug 2014 at 9:45pm
We had that happen way back and it was the low voltage.........we have gone on vacation and I forgot to disconnect the battery
