Page <1 567 |
![]() Posted: 16 Sep 2014 at 1:38pm |
Exactly. Some will even add foam pipe insulation around the first few feet of water line for extra vibration protection. Another option is to add an accumulator tank, too.
Budward ![]() Senior Member ![]() Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
I added an accumulator to my 1999 toy hauler, while it stopped the pump from short cycling so much it didn't really quieten it as I recall.
The pump in my 179 is marketed as an "accumulator not needed", and sure enough it never short cycles. |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
Pump started making lot's of noise. Lifted cover to HW heater and moved hose away from metal it was banging against. Problem solved. Foam insulation and/or a few zip ties would probably be a better permanent fix.
Page <1 567 |
