| Author |
Outbackdave
Topic: TV / Generatoor Posted: 20 Jul 2014 at 8:36pm |
Is it safe to use the TV withe the generator running. Have a 3500 Champion?
176T, Dodge Dakota TV,
South Carolina
Dave,Mary and Olivia(sheltie)
Suzuki V-Strom Adventure,
Custom built TearDrop
dockguy
Posted: 20 Jul 2014 at 9:38pm |
Hi Fellow Camper,
It is ok to use an inverter generator with your tv, but not a home generator. If it is not an "inverter generator" it may fry you tv.
Inverter generators are made specifically to run electrical equipment like tv's, computer, etc. They are different than a regular household generators as these generators surge electricity which can fry your tv, etc.
Hope that this helps... Dockguy 2005 Toyota Tundra 2011 Rpod 171
Randy/ dockguy
CharlieM
Posted: 21 Jul 2014 at 9:42am |
Generally it's OK, even with a non-inverter generator. However, you should use a surge protector like the SurgeGuard just like you would use at a campground and I would not start the generator with the TV or anything else connected. .
Old Dingo&Mrs.Dingo
Posted: 21 Jul 2014 at 10:30am |
If it's a 12 volt TV w/ a transformer, run it on battery and the battery will absorb any surges. that said a SurgeGuard (or it's equivalent) is a smart investment for any of us.
Old Dingo and/or Mrs. Dingo
181G
2013 Jeep Grand Cherokee
CharlieM
Posted: 21 Jul 2014 at 10:47am |
Originally posted by Old Dingo&Mrs.Dingo
If it's a 12 volt TV w/ a transformer, run it on battery and the battery will absorb any surges. that said a SurgeGuard (or it's equivalent) is a smart investment for any of us. | Agree 100%. If the TV is the same POS as in my 172 it is 120V only. However small inverters are available (Radio Shack) so it can be run from 12V. Most useful while boondocking, but would also add protection from the generator.
Sleepless
Posted: 21 Jul 2014 at 10:48am |
We use a 5000 watt generator during hurricanes and other outages for over 20 years. We have surge protectors on our TVs, computers, etc., and don't worry about it not being an inverter. The same is true for running a regular generator for our pod, although we do use a surge protector there, too. I carry a quiet 1000 watt generator, just in case we have no hook-ups and we want to watch TV or use other small appliances.
2014 R-Pod 178 (OUR POD)
2009 Chevrolet Avalanche
WillThrill
Posted: 27 Jul 2014 at 4:59pm |
A surge protector should be used (in theory) all the time, no matter what kind of generator you are using or even (especially!) if you're connected to shore power.
The power produced by a regular generator is fine for all standard home electronic equipment and is better than a lot of the shore power you get in some campgrounds. If you're connected to shore power, you absolutely need a surge guard.
2014 Hood River 177
2005 GMC Envoy XL
Posted: 28 Jul 2014 at 11:30pm |
To clear up a misconception, modern power supplies (computers, televisions, etc) must accept a large range of inputs by spec, well beyond the normal utility sinewave. There is no problem feeding them the dirty power from a cheap genset. In fact, many of them will operate from DC (90-260 volts).
