  New Posts New Posts RSS Feed: Water Pump Noise - Does Not Sound Right
Topic ClosedWater Pump Noise - Does Not Sound Right
RPodWeGo View Drop Down
Direct Link To This Post Topic: Water Pump Noise - Does Not Sound Right
    Posted: 05 May 2014 at 6:48pm
When the trailer was newer, whenever I turned on the water the pump made a nice humming sound, now it makes a "struggling sound"???  Also, when I used to turn off the water the pump would stop almost immediately, now it continues with the struggling sound for some time, sometimes long enough that I turn the pump off at the panel.  I have checked the filter, and did not find any debris.
Any ideas?
RPodWeGo
RPod 177
04 v8 Toyota 4Runner
Budward View Drop Down
Direct Link To This Post Posted: 05 May 2014 at 7:06pm
Could it be drawing air?  When the water is coming out of the faucets is it nice and solid or full of air bubbles?
2014 179
Direct Link To This Post Posted: 05 May 2014 at 9:51pm
Yup, I would check the valve right at the water pump, the one used to draw in antifreeze when winterizing.  It could be slightly open, allowing air into the system.
Direct Link To This Post Posted: 06 May 2014 at 12:53am
Good ideas guys.  I added a valve for winterizing last fall, I'll check though I think you are onto something.
RPodWeGo
RPod 177
