Budward
Topic: Rear stabilizers on Rpod 178 Posted: 24 Apr 2014 at 7:38pm |
Nice skid plates! I did something similar on a Featherlite enclosed trailer I have, only I used 1/2 poly cutting board material- figured it would slide well if it did touch down and if it got torn off it is cheaply replaced. Like you they've never hit, but one day I'm sure they will. The Featherlite is all aluminum, frame/floor/everything so a touchdown could be quite damaging.
Seanl
Posted: 25 Apr 2014 at 10:34am |
I have the older style long arm jacks not the new s cissor jacks. I tore one of them off a couple of years ago on a steap hill and damaged the fiberglass ont he back of the trailer. The nice thing of these jacks is that they are bolt on not welded.
marwayne
Posted: 25 Apr 2014 at 12:48pm |
I to have the old style of jacks, but I found that there was quite a bit of movement in the front from side to side, so I turned them like they do the scissor jacks. It makes the pod a lot more stable. I also find the old jacks don't hang down as far when cranked up.
Keith-N-Dar
Posted: 25 Apr 2014 at 8:02pm |
The scissor jacks bolt on as well. The weld appears to me as a tack to keep them in place while the assembler drills the holes in the frame. It is hardly structural.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Hairy Podders
Posted: 27 Apr 2014 at 7:14am |
More than likely the tack weld is liability based. If they were tack welded at the factory, the chance of them falling off & injuring/damaging something/someone is greatly diminished.
Darryl, Julie & Lindsey
2014 RP178
