  New Posts New Posts RSS Feed: First trip
Topic ClosedFirst trip - Event Date: 07 Jun 2013 - 09 Jun 2013
hogone View Drop Down
Direct Link To This Post Calendar Event: First trip
    Posted: 13 Jun 2013 at 6:53am
curiosity question............if for some reason they weren't accurate what would happen, let's say on the gray tank.  Would the water just back up or not drain?  Am I to assume it would be pretty obvious?  My gauges seem to be fairly accurate as well.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
CharlieM View Drop Down
Direct Link To This Post Posted: 13 Jun 2013 at 7:24am
I've actually observed this in the process of measuring the capacity of my tanks. The gray water will begin to drain slowly and back up into the shower. You may also hear some gurgling in the kitchen sink drain as the air attempts to escape. For the black water the back up will be into the toilet bowl. Fortunately you can see this coming if you look down the toilet as you flush. You will have some warning when it's getting full.
All in all real messes can be contained, but it's really worth some effort to keep the gauges working by back flushing and cleaning. I have used the Geo Method with some success. And, if you're into such things, it helps to run a test to see how the gauges respond to varying fill levels. This can be done with a known 5 or 6 gallon bucket. The gauges are not linear. I have an additional 10 gallons of capacity after the top light comes on. Good to know what that top light really means.
Direct Link To This Post Posted: 13 Jun 2013 at 8:22am
Very helpful Charlie, thanks.
Jon & Pam
2013 RP177
2010 F150
2017 HD Streetglide
2009 HD Lowrider
CHEESEHEAD
