Separate circuits |
Folornhope
Groupie Joined: 22 Nov 2010 Location: Texas Online Status: Offline Posts: 51 |
Topic: Separate circuits Posted: 13 Mar 2012 at 5:42pm |
The fridge didn't worry me too much as it would still run off the battery so the food wasn't an issue. But killing my coffee pot didn't make me a happy camper. The suggestion? Put the outside power outlets on a separate GFI circuit. The cost for this fix would be minimal.
Posted: 14 Mar 2012 at 2:42pm |
A tripped GFCI shouldn't affect the outside light, that runs off of 12 volts. Odd. I agree with your suggestion.
tpierce220
Senior Member Joined: 14 Jan 2011 Location: Oswego IL Online Status: Offline Posts: 281 |
Posted: 15 Mar 2012 at 10:12am |
Did you check your fuse box to see if something was tripped there as well? We had an electrical issue on our last trip out last year and found that seemed to be our problem.
Posted: 15 Mar 2012 at 12:52pm |
If you look, at least in our 177, 2 extra slots in the fuse box...
and yes, the porch light is on the 12v circuit.. and run the fridge on 12v LAST.. it will run a LONG time on gas. The "burner" is no bigger than a pilot light. |
Posted: 15 Mar 2012 at 3:20pm |
I had the same reaction at first, but then realized since they had hookups it was no different than running it in AC mode. He wasn't really running it off of "battery", but rather from the converter.
With no hookups you are absolutely correct, though. It would kill the battery in just a few hours.
Folornhope
Posted: 17 Mar 2012 at 5:23pm |
Yeah...had hookups, so I put it in battery mode...since we were on shore power I wasn't worried about battery life. Otherwise it would have been on propane. Yes, had checked the fuses (none were bad), also checked the breakers, none were tripped. Took the outside outlets off latter and checked the back side, they were dry as far as I could tell. I have Eddy back home now and will check on this more latter as he now has a more pressing issue...see my post Gaaaahhh.
Eddy the Escape Pod...177
Ford F150 |
