  New Posts New Posts RSS Feed: Inside Wooden Panel Loose
Topic ClosedInside Wooden Panel Loose
MikeP View Drop Down
Direct Link To This Post Topic: Inside Wooden Panel Loose
    Posted: 19 Aug 2018 at 10:18pm
Hey folks. I wasn't able to find if this has already been asked, but has anyone experienced an issue where the wooden panel directly to the left of the fridge (if you're standing in front of it) doesn't want to stay in place?  It's the piece that slides as you're moving the slide in and out and is held in place by 3 long screws. It actually popped off and was laying on the floor on our trip back today.  Appreciate any thoughts or re-direct to an existing thread if one exists.
MP2112
crankster78 View Drop Down
Direct Link To This Post Posted: 20 Aug 2018 at 9:07am
Greetings
I used larger self taping screws to mount the panel in my 179. they have worked well for a couple of years  the heads of them are visible, but no big deal.  They anchor into a sheet metal flange so the panel will still flex a bit.
Crankster78
Crankster 78 R-179 2015
Direct Link To This Post Posted: 20 Aug 2018 at 9:32am
I ended up putting in toggle anchors since even larger screws were not working. It has stayed in place for several trips now. I have thought about putting a hinge there, but it would need to be a double hinge to be able to flex if something were in the way either as the slide was being extended or when it was being retracted. I have not yet found a suitable double-hinge for that purpose.
TheBum View Drop Down
Direct Link To This Post Posted: 20 Aug 2018 at 11:54am
I think we may be talking about different things. The OP said the panel is to the left of the fridge, whereas the problematic panel in the 179 is under the fridge.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 20 Aug 2018 at 1:39pm
The only "panel" to the left of the fridge would be the trim around the slide-out. Unless something was stuck behind it when extending the slide-out, I don't see how the trim could come loose. OTOH, the panel under the fridge has been a problem more than once for me.
Direct Link To This Post Posted: 20 Aug 2018 at 2:04pm
The OP doesn't say which Pod he has, so he may not be talking about the 179.
It may be the trim. I know we had issues with the trim on the opposite side of the slide in our 179 when the cover for the ottoman storage would come loose and pry the trim off as the slide opened. We started throwing it on the bed and haven't had a problem with it since.
Alan
Three cats
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 20 Aug 2018 at 2:06pm
As I run through the unit, travel down the road.. You're going to find several come loose...
Sorry, but I've fixed so many spots now.. Not glued, short pins, no screws...
Don't get me wrong, I do love 'Lily'! She's been very good to us! I just see she needs a bit of TLC to keep everything in place.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 20 Aug 2018 at 7:31pm
...or it's possible the newbie OP is such a newbie that he misrepresented the true issue, which in fact happens to be the panel "under the fridge" on his brand spankin "new" 2015 179...whoops.  Sorry guys. And thanks for the suggestion. I'm guessing this will be something I'll have to do some tinkering around on.  Have a great evening.
MP2112
