dual battery connections |
spentwings
Newbie Joined: 02 Oct 2016 Location: MT Online Status: Offline Posts: 9 |
Topic: dual battery connections Posted: 02 May 2017 at 6:17pm |
Leo B
podders Helping podders - pHp Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4507 |
Posted: 02 May 2017 at 8:12pm |
Posted: 03 May 2017 at 7:28am |
You need more connections then that to get it to work..
spentwings
Posted: 03 May 2017 at 8:38am |
Maybe I was not clear enough yesterday. The wires I intend to reconnect are the same ones I removed before winter. Dual cables, taped together from from the r-pod, two reds, one black & white cable also from the r-pod. Plus, separate red and black cables to connect the opposite battery. I have a photo, but not sure how to insert it in this post, sorry. Here is what I have:
Two 12v Batteries, 1' Dual Red wires from the RV 2. White+black together, from the RV 3. One red to connect the two batteries 4. One black to connect the two batt's. Assuming I read correctly, I connect in this fashion:
Good decisions come from experience. Experience, well.... that comes from bad decisions.
Posted: 03 May 2017 at 9:01am |
Well.. since your OP is blank.. yes, you were not clear enough... LOL.. (we don't know why, but every now and then a post comes through blank.. some of us use the opportunity for some levity until it gets cleared up) It sounds as if you have a solid handle on it, as you describe. |
CharlieM
Posted: 03 May 2017 at 9:05am |
It sounds like your suggested method of re-connection is correct. Two 12V batteries should be connected in parallel. The only confusing thing about your post is the two red wires taped together and the black and white combo. Most PODs have only a single red and single white, but if they are tape together it sounds like the previous owner or the factory intended them to be connected together. The connection of reds to one battery and black+white to the other battery as you describe is the preferred way.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6283 |
Posted: 03 May 2017 at 9:34am |
If there are wires taped together, it might be the Zamp power wires. I have four wires on my 'Pod. Two are heavier, and are for the general R-Pod connections. Two do not have terminals and were not connected. This second pair connect to the Zamp power connector. Since I don't have solar panels, I have left them unconnected.
CharlieM
Posted: 03 May 2017 at 9:46am |
Good put. If they are the solar connections that's the way they should be connected. |
