Swhalen2
Calendar Event: Anyone using a Toyota Highlander Posted: 29 Mar 2017 at 7:10am |
We are looking for a new tow vehicle. We are considering a Toyota Highlander. Has anyone used or are using one currently and if so, how does it perform? We currently have a 171 and an 2002 F-150 and would like to use a SUV. Any suggestions?
Wilderness does not have a compromise.
TheBum
Posted: 29 Mar 2017 at 10:20am |
I can't speak for the current generation Highlanders, but we tow our 179 with a 2012 Highlander 3.5L V6 with tow package and it does a good job. The only times it has ever been incapable of maintaining the speed limit were on a couple of 9% grades in WV. It probably wouldn't have had a problem with a 171.
You might also take a look at the Dodge Durango. The V6 is in the same price range, has a few more HP, has an 8-speed transmission (the HL is only available with a 6-speed), gets about the same gas mileage, and has a 6500 pound tow rating. When it comes time to replace my wife's SUV, this is the vehicle I'm seriously considering.
Swhalen2
Posted: 29 Mar 2017 at 11:35am |
Thank you! The new Highlander has an 8 speed transmission. Good information on the Durango.
Sean
TheBum
Posted: 29 Mar 2017 at 11:46am |
I didn't realize that the HL had gone to an 8-speed.
Unless you plan to go AWD, the Durango would be a better choice for towing because it's RWD. It also has a proper frame, not a unibody like the Highlander.
Swhalen2
Posted: 29 Mar 2017 at 12:18pm |
You make a good point. I was getting the AWD that can be locked in while towing but after reading your responses, will look around more. Thanks again.
Sean
Steve 911
Posted: 29 Mar 2017 at 11:35pm |
We pull our 2017.5 179 with no problem. Although I have to say, I haven't pulled over the Rockies yet..lol Our TV is a 2016 Highlander AWD with factory tow pkg. my problem is, I have to remember it's back there. I find myself going faster than I want to sometimes on the freeway. In time, I will find the sweet spot for my setup ... Good luck
Firefighter Steve (retired)
2017.5 Rpod 179 (Reepod)
2016 Highlander AWD w/tow pkg.
E2 wdh, prodigy RF brake controller.
