  New Posts New Posts RSS Feed: Roof leak in my brand new Rpod!
Topic ClosedRoof leak in my brand new Rpod!
Chris and Sarah View Drop Down
Direct Link To This Post Topic: Roof leak in my brand new Rpod!
    Posted: 24 Mar 2017 at 2:49pm
Wanted to seek some advice.
The Air dam/spoiler (?) above the back window on my 2017 171 apparently wasn't caulked correctly at the factory, and it caused water to leak into the Rpod, primarily into the light fixture above the bed (and then down onto the bed), and in a heavy rain behind the ceiling panel and down the back wall onto the curtains and the bed.
Video showing the leak is here:
Thankfully this is all covered under the warranty.  When I brought the Rpod in, I had originally asked the repair technicians to remove the entire ceiling panel over the bed so that I could inspect the wood for any signs of mold and mildew.  However, the technicians don't seem to think that's a great idea.  They removed the trim pieces from the top and bottom of the panel which allowed them to pull the panel down just far enough to stick a flashlight in for a visual inspection, and they've said that they don't even see water stains on the wood.  They've warned me that if they remove the whole ceiling panel, that they'll have to cut the rubber seals where the walls meet the ceiling and it may not look just right when they put it back together. However, they'll do it if I want them to.
So I checked with the flashlight and sure, I don't see any signs of water damage, but I'm seeing a tiny fraction of what's behind that ceiling panel -- not nearly the whole thing, and not where the water was coming in.  In addition, I'm worried about the insulation -- the insulation definitely got wet -- so can anything grow in there?
I'm not sure if the right thing to do is just to take the technicians assurance that we caught the leak early and there's almost certainly nothing growing, or if I should tell them to pull it down, cosmetic difficulties with reinstallation be damned.
Any advice would be greatly appreciated.
Direct Link To This Post Posted: 24 Mar 2017 at 3:18pm
Sorry to hear (and see) your leaky problem.
My concern would be trapped moisture. The insulation used in the ceiling panels is quite capable of retaining moisture. If you can remove the light fixture and pull some insulation, I would.
You may not notice trapped moisture for a long time - until vinyl wall covering begins to blister from the softened luan. You could drill a few small "inspection" holes to look for trapped moisture or get a hold of a moisture meter.  Also, pay close attention to the bottom inside back edge (in the storage space) for any water which may have run down the back. The insulation will allow for water to wick horizontally and vertically.
Over a longer period, I would tap the panels looking for any soft spots.
Because of the way the Pod is constructed, I don't blame them for not wanting to remove ceiling panels. The walls go up, then the interior ceiling panels are attached, then insulation is added, then the exterior fiberglass shell is attached. With the interior ceiling panels sandwiched between walls and exterior shell, it's a difficult project to replace interior ceiling panels.
I have learned this lesson. Best to do everything you can to avoid water intrusion...if you can.
Hope that helps.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 24 Mar 2017 at 4:33pm
 Make them fix it which means removing and replacing the wet insulation as well. If they button it up with moisture inside, it will create other problems down the road.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
Direct Link To This Post Posted: 24 Mar 2017 at 8:25pm
Dealer WARRANTY.  As Toolman John states "MAKE THEM FIX IT."  Or better yet, let them replace it with a brand new 171.
Direct Link To This Post Posted: 25 Mar 2017 at 1:04pm
Thanks everyone.
I made them pull the ceiling panel off, and there was no moisture in the insulation like I feared there would be.  The water was passing through and then eventually came out from the panel on the bottom, so the insulation didn't soak it up.
Direct Link To This Post Posted: 25 Mar 2017 at 3:53pm
Peace of mind, better than not knowing. Good that the outcome is successful.
2013 VW Touareg TDI
Direct Link To This Post Posted: 26 Mar 2017 at 11:53am
I wouldn't have worried once the leak was fixed.  It was caught quickly so rot wouldn't have been an issue.  The walls "breathe" so any moisture would have dried up soon after.
