  New Posts New Posts RSS Feed: Solar Battery Maintainer
Topic ClosedSolar Battery Maintainer
mcarter View Drop Down
Direct Link To This Post Topic: Solar Battery Maintainer
    Posted: 26 Mar 2017 at 3:39pm
SH,
I first saw them at Fort Hood during the early days of Hummers. Every unit had them, I suppose they were purchased with unit funds, they were pretty available.
As far as battery switches, I use the big red key switch, mounted in a plastic electrical box, mounted on the tongue next to batt. I can turn it on/off and remove the key.
Direct Link To This Post Posted: 26 Mar 2017 at 3:17pm
I am using a Marinco BEP battery switch. Installation was eaxy. The hardest part was f\iguring out where to put it. There is a picture of it installed in my mods.
Wepod View Drop Down
Direct Link To This Post Posted: 26 Mar 2017 at 10:40am
Ok thanks,   So what battery switches are being using?
Direct Link To This Post Posted: 24 Mar 2017 at 4:52pm
Interesting concept. I never saw one of these during my 26 years in the Army. It might have been something that was being evaluated by select units.
Direct Link To This Post Posted: 24 Mar 2017 at 4:34pm
X1 to furpod, if you want to use a solar charger, look at Solargizers, the Army used them for years to maintain batts in the motorpool. Used to be they would give you a Solargizer when they issued the vehicle.
Direct Link To This Post Posted: 24 Mar 2017 at 2:17pm
Unless it's going to sit for more then 6 months, if you use a cut-off switch, you won't need a maintainer of any kind.
riotkayak284 View Drop Down
Direct Link To This Post Posted: 24 Mar 2017 at 2:07pm
I just use a switch to cut off the current and never have had it not be good after....
Direct Link To This Post Posted: 24 Mar 2017 at 1:51pm
Is anyone using a solar panel to maintain the charge on the battery's while there pod is being stored?   I am planning on installing a battery switch so i am just looking at keeping the battery topped off not something to take care of house loads.
