On board battery monitor |
Post Reply | Page 123> |
Author | ||
Topic: On board battery monitor Posted: 02 Mar 2017 at 6:02pm |
Photo of my install on 178:
https://s5.postimg.org/epzj6qps7/20170110_112519_001.jpg |
Posted: 02 Mar 2017 at 9:38am | |
Our Lance has a 12v television that is great. 32" HD LED. Nicer then the Sony in our living room.. LOL |
TheBum
Posted: 01 Mar 2017 at 5:57pm | |
Yep. There aren't nearly as many options in 12VDC TVs as there are in 110VAC TVs. |
ToolmanJohn
Posted: 01 Mar 2017 at 4:48pm | |
I recommend you instead install a small inverter and get it wired to provide power to the TV instead. I installed a 400 watt inverter under the dinette bench where the converter is. It has an on/off switch, cost $40, and has a USB charge port also for my phone (which is 99.9% of why I have it). My LED TV is a Wal-Mart whatsit brand I bought for $60 about 4 years ago. It has a max power consumption of 22 watts. If you really want to run a DVD player too, that would use a few more watts. What I'm saying is, a regular small 120 VAC TV is better than any 12 volt TV by a long shot.
Steve 911
Groupie Joined: 09 Sep 2016 Location: Northern Ca. Online Status: Offline Posts: 92 |
Posted: 01 Mar 2017 at 2:56pm | |
I watched that youtube video. could not be any easier..
Thanks
Firefighter Steve (retired)
2017.5 Rpod 179 (Reepod) 2016 Highlander AWD w/tow pkg. E2 wdh, prodigy RF brake controller. |
Lear111
Groupie Joined: 20 Oct 2016 Location: Montgomery, tx Online Status: Offline Posts: 66 |
Posted: 01 Mar 2017 at 2:37pm | |
https://m.youtube.com/watch?v=4cfKqzVuRp
If link did not go through. Google rv voltmeter install. You tube video will show absolutely the easiest way to do it. $10 dollars from Amazon and anyone with a Phillips head screwdriver can do it. |
Steve
Lexus GX460 R-pod 180 2017 1 black lab |
TheBum
Posted: 01 Mar 2017 at 1:20pm | |
There's at least one extra fuse slot in the power panel. I used one of those to power a 12V outlet, some USB ports, and a 400W inverter, which allows us to watch the 110VAC television while running on battery. |
TheBum
Posted: 01 Mar 2017 at 1:18pm | |
The one I have stays on and I think it's definitely a concern. You can easily fix it by going to Radio Shack and getting a momentary normally-open pushbutton to wire in series. |
Steve 911
Posted: 28 Feb 2017 at 11:03pm | |
Thanks,
I think I'm going to add a couple of 12v outlets and USB ports as well. I want to change out the 110v television, that came with my new 179, to a 12v television. I'm just not sure exactly where to tap into 12v wires.
Posted: 28 Feb 2017 at 10:01pm | |
You are correct that the R-Pods do not come with any 12V outlets (unless there has been a change in the latest models). I added a triple outlet (2 12V power socket type and 1 USB charger) next to the 110V outlet at the base of the bed. I added a second 12V power socket and a USB charger outlet mounted individually near the television. I mounted a 12V digital meter next to the indicator panel. I added the 12V sockets so I can run my CPAP machine and the USB outlets so we can charge our phones.
