  New Posts New Posts RSS Feed: I wrecked our escaPod
Topic ClosedI wrecked our escaPod
 Post Reply Post Reply Page  <1 1516171819>
Direct Link To This Post Topic: I wrecked our escaPod
    Posted: 16 Jun 2017 at 3:28pm
Now it's time to go camping.  The other stuff can wait until the weather turns.
birderdiane526 View Drop Down
Direct Link To This Post Posted: 16 Jun 2017 at 5:11pm
Congratulations! Good luck prepping for your trip!
Diane and Michael
2007 Toyota Tundra
BLOG:Podding in Paradise,
birderdiane526.blogspot.com
Direct Link To This Post Posted: 16 Jun 2017 at 9:06pm
Unfortunately, there is no time to do camping before our big trip so some of the things need to be put back in and the 'Pod stocked for the trip. On top of that, we will be helping with VBS next week. The days are going to be packed in getting the R-Pod ready.
I already got the double steps put back on as well as the power jack. I re-did the steps so now they fit even better than before. I also reinstalled the vent cover. That is tricky as I was surprised to see not the Fan-Tastic Vent, but a Maxxair Vent when we went to pick it up. I had to modify the Fan-Tastic Ultra Breeze vent cover to use the Maxxair's mounting tabs. Hopefully, it will work. If not, then I will get the Maxxair Fan-Mate cover that will use the EZ-Clip mounts.
Dave & Donna View Drop Down
Direct Link To This Post Posted: 16 Jun 2017 at 10:17pm
I'm Glad you have your Pod back! Have a great time on your trip. When you have the time, I'd lime to know about the double steps. That is a Very long step dowm!!
D.
D&D plus Rusty
2017.5 R-pod 179
Direct Link To This Post Posted: 16 Jun 2017 at 10:36pm
There is a picture and description on page 4 in my mods (link in signature). I had to notch out the back end to have them fit correctly. The end plates are wider than those of the original steps. They are also a little narrower, so I made shims so they would fit. I could have used washers if I had wanted to, but had the stock on hand to make the shims.
Direct Link To This Post Posted: 17 Jun 2017 at 12:11am
Originally posted by StephenH
Thule Awning: This is what I have been wanting. It does not quite match as it is made for the blue/gray color scheme. However, it looks great and is simple to deploy/recover.
Did they reinforce the structure to hold the awning, or do something on the exterior to make sure it doesn't detach?
Direct Link To This Post Posted: 17 Jun 2017 at 6:42am
Yes. Since they had to replace both the door side and re-do the roof, they reinforced it so it could support the awning. I would not recommend having an accident in order to get an awning installed. However, in our case, it happened to work out.
Direct Link To This Post Posted: 17 Jun 2017 at 3:33pm
Thank you for the information on the steps!
D.
D&D plus Rusty
2017.5 R-pod 179
Direct Link To This Post Posted: 17 Jun 2017 at 5:01pm
I was a little unclear in my description above. The end plates are wider, but the steps are a little narrower, meaning the end plates are a little closer together. That is why I needed the shims. When I reinstalled them, I reworked the notch so they now sit better than they did before. I needed to deepen my notch about a 1/4 inch. Now they are level whereas they were slightly tipped up before.
Direct Link To This Post Posted: 17 Jun 2017 at 9:45pm
Okay, I am trying to post a photo, but even though I get the link from Google photos and put it in the URL of the dialog box for pictures, all I get is a broken link. I'll try again tomorrow.
Edit: I am trying again after a good night's sleep.
Okay, what am I doing wrong? I paste the link from Google Photos in the URL box but then I get an error message. Are photos from Google blocked on the forum?
