  New Posts New Posts RSS Feed: Hitch care
Topic ClosedHitch care
TheBum View Drop Down
Direct Link To This Post Topic: Hitch care
    Posted: 01 Dec 2016 at 6:02pm
Originally posted by furpod
You can also buy a self lubricating ball. We have run one for the last 3 years, very happy with it.
I looked for one this afternoon with Google's help and couldn't find a 2" one that would work with a regular hitch bar. The only ones that would were 1-7/8".
Direct Link To This Post Posted: 01 Dec 2016 at 2:56pm
When we first got our R-Pod, I did not grease the hitch ball. Even on the first trip home, I noticed wear on the ball. That is when I decided I had better lubricate it. I put grease on it before hitching. When I unhitch, I take a couple of paper towels and wipe the dirty grease off. Then I put a rubber hitch ball cover on.
Next time I get ready to hook the hitch up, I'll have to get a picture of the wear.
Direct Link To This Post Posted: 01 Dec 2016 at 1:47pm
28 years of trailer towing here, and I've never lubricated the hitch ball or the sway bar ball (when I had one). I've never noticed any wear, or noise from those locations (only from the intentional friction points).
If you leave the ball in place now you have a greasy ball where you'll walk into it. My father greases his ball and after borrowing his utility trailer last week I left my ball on and sure enough, my wife leaned over it in a white shirt...
That said, if you do grease the ball there are ways of covering it when you are unhitched.
Direct Link To This Post Posted: 30 Nov 2016 at 11:06pm
Originally posted by TheBum
I wonder if those Sway Bracket Jackets would fit the Fastway E2 L-brackets.
They might fit. The Equal-i-zer web site (Progress Industries makes both the Equal-i-zer and the Fastway E2) states not to lubricate the brackets on the E2 as the friction of the bars and brackets are the only sway control the E2 has. The Sway Bracket Jacket does reduce friction some also, but the Equal-i-zer also has the hitch head and bar pivot points as part of the sway control also. I did not really notice too much difference with and without them except that it is a lot quieter with them.
I would address the question to the manufacturer. That would be the best and most accurate information on whether they can be used or not.
Bama Pod View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 6:52pm
Hmm - I've never considered that I need to lubricate my balls.
Now on my TODO list.  Thx.
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
kansasfrogs View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 5:43pm
Thank you all for your help.
FROGGY
Direct Link To This Post Posted: 30 Nov 2016 at 5:41pm
Shelpod View Drop Down
Direct Link To This Post Posted: 30 Nov 2016 at 5:01pm
Just on caveat.  If you have the Andersen WHD you should not lubricate the ball.  The manual specifically warns against it since the ball is locked in place above and below when the hitch is fully set up and there is a sleeve that the ball post sits in that acts as part of the sway dampening system.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package
Direct Link To This Post Posted: 30 Nov 2016 at 3:56pm
Direct Link To This Post Posted: 30 Nov 2016 at 3:51pm
+1
