Blowing out water lines |
Post Reply | Page 123> |
Topic: Blowing out water lines Posted: 05 Nov 2016 at 6:44pm |
I figured, just wanted to be sure.
Posted: 04 Nov 2016 at 6:08am |
Doug, you are absolutely correct . . . . as usual. I meant to say heater element but didn't. Anyway, thank you for correcting my goof. I am still on my original anode rod AND since I replaced my heater element in April 2011, that is still good as well.
Posted: 03 Nov 2016 at 9:10pm |
Anode rod is not the same as the heater element. The latter is what will blow right away if there is no water in the tank.
Posted: 02 Nov 2016 at 11:26pm |
Been there, done that, got the wet tee shirt (and face full of water). At least it was cold as I had turned the heater off a couple of days before I removed the anode rod.
Tars Tarkas
Posted: 02 Nov 2016 at 11:02pm |
I agree, also with the comment that this is a good opportunity to check the condition of the anode. The only thing to remember is to relieve the pressure from the hot water heater by either turning off the water and opening the hot water faucet at the sink or by opening the relief valve on the water heater. Removing the anode under pressure can result in a dangerous projectile or a face full of water. TT |
FJ Cruiser |
Posted: 02 Nov 2016 at 9:47pm |
I don't believe that is tied to the hot water tank, only the hot water lines. Quite easy to put a socket on the hot water anode, drain, and re-install.
IdahoBoy
Groupie Joined: 24 Oct 2015 Location: Ketchum, Idaho Online Status: Offline Posts: 65 |
Posted: 02 Nov 2016 at 9:40pm |
So there is a hot water low point drain on my 2016 172. Is that not adequate to drain the hot water tank?
Posted: 02 Nov 2016 at 9:34pm |
Anode rod should last a long time, except when owner (me) forgot to open the 3 bypass valves and then turn the hot water tank on. That anode lasted maybe 15 seconds. Since then (April 2011) I have been on the same anode rod, only use well water, maybe that is why it is lasting as long as it has, no chemicals in it like what municipal water contains.
Posted: 02 Nov 2016 at 9:08pm |
One advantage of removing the anode rod is that you get to check the condition of it. We have had our Pod 11 months. I have had the anode rod out after every major trip. We are still on the anode rod that came with the Pod. Suburban says to replace when 75% of the anode rod is gone. I took and weighed a new one. I then weighed the one that is being used. It is currently still over 50% of the weight of a new one, so I figure it is good for a while longer. While it is out, I flush the water heater out to get the sediment out. I use new Teflon tape and put it back in so it will be ready for the next trip.
Tars Tarkas
Posted: 02 Nov 2016 at 8:48pm |
I don't think removing the anode rod is critical at all, per se. It's important to get as much water as possible out of the water heater and probably the easiest, best, way to do that is to remove the rod. You can then put it back in. If you're confident of getting as much water out of the water heater some other way, the results would be the same.
TT |
FJ Cruiser |
