Page 12> |
jato ![]() Senior Member ![]() ![]() Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3346 |
![]() Posted: 22 Sep 2016 at 10:08pm |
A lot of excellent waxes on the market to choose from. We have used MeGuiar's ultimate liquid wax on our pod since 2013, and on our auto as well. Gives a finish that is baby butt smooth.
A couple things to add: Either purchase a screen cover for your two exhaust holes coming from the furnace to keep mice from building a nest OR (this is what we do) cover the holes with steel wool, that will keep them out as well. Secondly, we don't do the antifreeze thing, just use compressed air to blow out your lines, takes about a minute at most. That way you won't get that nasty antifreeze taste in the spring when you get a drink of water out of your cold water line. I will use about 1 pint of the pink antifreeze to put in the shower drain and two sink drains.
StephenH ![]() podders Helping podders - pHp ![]() ![]() Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6429 |
Overnight brief freezes which are in the 30's, and high 20's should be okay, especially if you have some form of heat running inside the Pod and leave cabinet doors open where there is plumbing. Extended freezes would, or course, require proper winterization. When we went out west last winter, we had some overnights in the low 20's. It was above freezing during the day though. and when it was coldest, we were running the furnace.
Jewel59 ![]() Groupie ![]() Joined: 19 May 2016 Online Status: Offline Posts: 70 |
I live in SC, my Rpod is in covered storage. I have a trip to FLA planned in mid December (dog show of course 😊). It won't be below freezing Florida and only a slight chance of below freezing up to December in SC. How much winterization is needed before that trip in December (it "might" get briefly below freezing by mid December, as in maybe - couple hours over night). It will be winterized fully after the December trip.
We had our pod 5 1/2 years, never covered it but it did need a heavy wash every spring due to tree sap. Can't hurt to cover part or all of it.
ron_whitt ![]() Senior Member ![]() ![]() Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
As for wax. I have used Nufinish for all my vehicles and also now on the pod. Love it.
Ron & Shirley
2020 Tacoma 2012 177 rpod |
I've been using Turtle Wax Ice. It is a synthetic polymer wax, and seems to work well. It can be applied in the full sun. I've been using it on my car (and previous car) for years.
As for covering the air conditioner, while probably not required, it would not be a bad idea if you are not using a full cover on the R-Pod. I've seen a picture of a cover made just for RV air conditioners. One of those would probably be best as it would fit the shape. I have a full cover (Classic Accessories) on our EscaPOD. It has two straps that run underneath to keep it in place. Since it is made for the R-Pod, I would expect it to stand up, even if it does get windy. |
HeyCampers ![]() Newbie ![]() ![]() Joined: 25 Aug 2016 Location: Colorado Online Status: Offline Posts: 12 |
This is all very helpful. In fortunately my travel schedule this year won't let us camp ithrough October, like Sean P. One question that hasn't been answered is a recommendation for a finish coating (wax). And one that I didn't ask: do I need to cover the air conditioner?
Thanks all, Thom |
No need for antifreeze in the gray and black tanks. Also no need to store the battery on a board, that solves an old problem from way back in the days when battery cases were slightly conductive so storing them on a concrete floor caused them to discharge. No problem with the modern plastic cases.
See the link in my signature for a winterization checklist. |
Thom, we put dryer sheets everywhere inside the pod and put some cotton balls soaked in peppermint oil in dishes covered with saran wrap with a couple small holes in the wrap. These we also put everywhere including the storage areas. We then place on the ground some moth balls under the pod as a first line of defence against mice etc. Starting our 5th winter and so far so good.
Ron & Shirley
Page 12> |
