Using your home clean out trap |
Post Reply | Page 123> |
Rebecca Dees
Newbie Joined: 21 Aug 2016 Location: Port NecheTexas Online Status: Offline Posts: 32 |
Topic: Using your home clean out trap Posted: 21 Aug 2016 at 8:57pm |
Does anyone use their home sewer line to dump their black and grey water? Thanks.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6285 |
Posted: 21 Aug 2016 at 9:22pm |
I do. There are two sewer drain openings on our property. One is by the house and the other by the curb. The way the ground slopes, the one by the curb is the better one to use. If we are at a campground with full hookups (or even a dump station), we will dump the black tank if it is 2/3 full, but I still drain and flush it again when I get home. I need to do that tomorrow as we just returned from a trip. Then the tanks will be empty and ready to use for our next trip. It is also ready if we have to use our R-Pod as a guest room.
Rebecca Dees
Posted: 21 Aug 2016 at 9:25pm |
Thanks. I'm wondering if I need to check with the city..??
Posted: 21 Aug 2016 at 10:23pm |
You don't check when you flush your home commode, do you? We pay water and sewer. I don't have a problem using what I am paying for.
Edit: As long as you are not flushing hazardous chemicals down the drains, it should not be an issue. If you weren't camping, you would be flushing your home commode, and probably using much more water in the process. |
Rebecca Dees
Posted: 22 Aug 2016 at 7:52am |
Lol! True! Thanks.
Posted: 22 Aug 2016 at 12:58pm |
Yup, go for it.
A note for those with septic systems. It is ok to use the cleanout by the house and the one on top of the septic tank (I confirmed this with my septic company). Do NOT use the cleanouts above the dry wells. All of the solid wastes get filtered out (consumed by bacteria) in the septic tank and only liquids should make their way to the dry wells. This is true for the newer sand-mound systems, too.
Rebecca Dees
Posted: 22 Aug 2016 at 1:11pm |
Techntrek... Thanks...I don't have a septic system but I'm sure those who do will appreciate your input. What side of the r-pod are the outlets on? Thanks again.
Outbound
Posted: 22 Aug 2016 at 2:19pm |
I've got a flowjet mascerator pump (aka The Poop Cannon) and pump through a hose to the plumbing stack in the basement.
I fitted a cleanout to the plumbing stack and then made a second cap (used only when dumping) with an aluminum hose connector epoxied into it. A couple more connectors on the FlowJet and the hose and everything just plugs together for an easy, leak-free tank emptying experience.
Rebecca Dees
Posted: 22 Aug 2016 at 2:24pm |
Outbound.. Thanks! Don't think I could have figured that out!!! Are you a plumber or an all-around know how guy?!!
M0tl3y
Groupie Joined: 21 Sep 2014 Location: Utah Online Status: Offline Posts: 61 |
Posted: 22 Aug 2016 at 5:18pm |
I've done the same as Outbound and fitted an extension from my basement plumbing out to my garage.
Like others have said, as long as you don't use any banned chemicals, like formaldehyde, then you can certainly dump your black/gray tank into your home sewer. I personally only use one cup of cheap laundry detergent and 1 cup of powdered water softener with each tank and it seems to do the trick with keeping the sensors clean and doesn't create a problem for the sewer system. It also allows for growth of good bacteria that can decompose the sewage.
The 178 club
