condensation on the windows |
Topic: condensation on the windows Posted: 17 Nov 2009 at 8:48pm |
Condensation has been a common problem, discussed elsewhere: We've had the problem the last 4 weekends we've been camping (its rained every weekend in October around here). Cracking 2 windows and cracking the vent an inch help, but its not perfect. This makes me think more about trying out the small-fan-under-the-shower-mod I've discussed before. The overhead fan is way too big... too much amperage when on battery power and too much air flow. A small 2" biscuit fan, installed under the shower where it would vent up through the vent already installed below the shower would be about right. Only problem would be the possibility of freezing up the water trap for the shower drain if its freezing outside. |
Posted: 17 Nov 2009 at 8:53pm |
This was suggested by Phil H as a solution often used by boaters: http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/375057/377%20710/0/solar%20vent/Primary%20Search/mode%20matchallpartial/0/0?N=377 |
Tusten Traveler
Senior Member Joined: 22 Jul 2009 Location: Catskills NY Online Status: Offline Posts: 235 |
Posted: 22 Nov 2009 at 10:05pm |
Since an air conditioner is the best dehumidifier, I wonder how it would work to run the AC on low with a heater- of course it would only be done when hooked up to electric. That's what we do in cars on a wet cold day.
John and Linda
One 14 lb Cockapoo 2010 RPod 174 |
yizit
podders Helping podders - pHp Joined: 25 Feb 2009 Location: Wis. Dells, WI Online Status: Offline Posts: 663 |
Posted: 22 Nov 2009 at 10:56pm |
If it is cold out side I believe the coils (or something) could freeze up
Former owner of 2009 172 Darlene & Jim, Ewok our Lhasa Roada our 2004 Roadtrek C190Popular |
3ofUs
Groupie Joined: 12 Jul 2014 Location: TN Online Status: Offline Posts: 99 |
Posted: 26 Jul 2014 at 8:27am |
Haven't camped in cold weather with pod, but in aliner we would leave the roof vent up a couple of inches when using the heat. This reduced condensation problem.
Budward
Senior Member Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Posted: 26 Jul 2014 at 9:16am |
That would work and I have done that in previously owned RVs. BUT- the rpod has that all in one thermostat that won't let you select heat and cool at the same time...aaah the wonder of modern digital stuff |
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
