  New Posts New Posts RSS Feed: Slide out
Topic ClosedSlide out
DawgLady View Drop Down
Direct Link To This Post Topic: Slide out
    Posted: 21 Jul 2016 at 7:31pm
I am on my first long trip with Lizzy(R 180) The screws are coming out at bottom of slide on both sides. Has anyone else had this problem and did you just try to tighten screws? I think they will just pull out again as slide seems to feel pulling when let out. Thanks
Dawg Lady
2016 R-180 "Lizzy"
Georgia
Direct Link To This Post Posted: 21 Jul 2016 at 10:25pm
Is this inside or outside? Where exactly are the screws that are pulling out? Do you have pictures? I will be looking at our 179 tomorrow when it is light.
Direct Link To This Post Posted: 21 Jul 2016 at 11:09pm
They are pulling out at the bottom of both sides of the slide on the outside.  I have watched from the inside while it is sliding and I can not see anything causing it to drag and  pull on the screws.
Dawg Lady
2016 R-180 "Lizzy"
Georgia
Direct Link To This Post Posted: 22 Jul 2016 at 9:14am
There are three rollers underneath the slide-out. If one of those is sticking, it might be sufficient to cause drag. Someone would need to be looking from outside as well as the inside to see what is happening.
Direct Link To This Post Posted: 22 Jul 2016 at 7:57pm
Thanks, will watch from outside. I can't get pictures to download from IPad as files are too large
Dawg Lady
2016 R-180 "Lizzy"
Georgia
par49 View Drop Down
Direct Link To This Post Posted: 21 Aug 2016 at 10:26am
Picking up my 180 next week.  Did you get this problem solved?  Were the screws coming loose on the slide out, only.  Or all around the camper.
par
Direct Link To This Post Posted: 21 Aug 2016 at 10:36am
On slide out only, bottom of. Both sides. It is at repair shop now and anxious to find out what caused this. Will post when I get it back and find out.
Dawg Lady
2016 R-180 "Lizzy"
Georgia
Direct Link To This Post Posted: 21 Aug 2016 at 4:03pm
We'll be waiting for your report. So far, I have not noticed anything similar, although it does look like the caulking around the edge of the black liner was done before the liner was pulled tight. It was bowed somewhat in the middle. I have since redone the caulking there and have not noticed any further slippage.
Direct Link To This Post Posted: 21 Aug 2016 at 4:22pm
Given that I am going to be 5 hours away from the dealer, this could be a real problem.  Thanks.
par
Direct Link To This Post Posted: 21 Aug 2016 at 4:29pm
par49,
Relax. This is likely a rather unique problem. I have not seen any other reports of screws coming out of slides in my reading of the forum. We got our 179 in December and have had 4 big and one small trips with it. We have not encountered any problems with the slide or its operation other than the very minor item noted above.
